newbie diesel owner questions
   / newbie diesel owner questions #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
My wife and I just purchased a beautiful 2006 F250 Lariat FX4 w/ the 6.o diesel and automatic. The truck has 52500 miles and looks brand new. It was leased then turned in. The only other diesel I own is my 2005 5103 JD. We will probably only put 10k miles a year on this truck, occassionally towing a 3 horse trailer, my tractor or my race car. As far as maintenance goes, what are biggies for this truck? I'll change the oil every 5k miles, but what about filters (fuel, air)? Anyone can give me some input on these trucks, what to watch for? We pulled a carfax on this particular truck and it came back perfectly clean. We also own a 97 F150 4x4 w/ the 4.6 and 3.55 gears, not much for towing. We decided the F250 diesel would be our best bet.
   / newbie diesel owner questions #2
I hope you got an Oasis report on the truck before you signed for the title. 6.0 Powerstrokes blow head gaskets, destroy turbos, shred timing chains, leak oil, and pretty much grenade in general. I don't mean that as a Ford or Powerstroke bash either, but that's exactly what most 6.0's will do.
   / newbie diesel owner questions #3
The first thing I'd do is change the fuel filters on the truck. They should be done ever couple oil changes. The 6.0 is hard on engine oil. I run full synthetic in mine and have seen good results. The engine is quiet, MPG's improved a bit and I get a bit longer between oil changes. One of the worst things for this particular engine is sitting. The varible guide vanes of the turbo need lubrication from operation for long life. I notice my turbo is sluggish if I don't run the truck for a few days. I know you said you won't be driving it much but I'd recommend driving it at least once a week on the highway preferably and get the engine hot. This engine is a good motor if you get a good one. The stigma of the 6.0 will never die. But the truth is there are alot of guys running them who swear by them. I've had a few small oil leaks fixed under warranty and the turbo was replaced at 33k. Other than the synthetic oil and having all the fluids changed and flushed I can't say you'll need to do anything else. Hope this helps
Matt:cool:
   / newbie diesel owner questions #4
The 05 and later 6.0 are probably the most reliable diesel of all the newer high HP trucks. They caught a bad rap early on but the damage was done by 05 when they had them straitened out. I own 2, a 04 and a 06, and both are trouble free. I have both pumped up to 500 or so HP and tow very heavy loads and still zero issues.
I change the engine oil every 5,000 miles and the fuel and tranny filter every 25,000 miles. I have Washable High Flow Air Filters and just clean and service them once a year. Along with that I do all the other maintenance spelled out in the manual and put fuel in them, thats it.
Chris
Chris
I actually read some of your previous posts regarding these trucks and diesel performance and was happy you put you 2 cents in. I have not pulled an oasis report on the truck but nothing showed up on carfax. So far I am impressed...it has plenty of power and I am getting 17.3 mpg (I checked with handheld calculator to be sure). For a 4x4 truck with 3.73 gears and 325 hp that is remarkable.
   / newbie diesel owner questions #7
Your average is about what mine run. Both have 3.73's and both are currently at the high 16 mpg mark. I run them hard though. Cant resist running down Camero's and Mustangs. Try driving it by the tach on the highway. I set my tach at 1,900 rpm, the sweet spot on the 6.0. This is 79mph, our speed limit is 75 here so I am right with traffic. With my chip, 4" exhaust, and intake/filter upgrades I see high 23 mpg.
Enjoy the truck.:D
Chris
   / newbie diesel owner questions #8
I think you got a good truck. I have a 05 F350 Dually with the 6.0 in it. Change the fuel filters every 2nd oil change. The only trouble i have had was turbo went out at about 45,000 miles was replaced under warranty and the mechanic said the best way to keep it working good was to run it hard every so often.
Like DiamondPilot said the 05 and 06 model 6.0 are good engines.
Enjoy the truck.:D
Chris
I am hesitant to upgrade the performance too much for fear of breakage, but what is out there to hit, say, 20mpg?
   / newbie diesel owner questions #10
Deerefan
My wife and I have a Powerstroke 07 Lariat 4 x 4 with approx 24,000 miles on it, it mostly pulls our Featherlite 3 horse LQ. I have never had not one issue with this truck.
I change the oil in the winter every 2,500 to 3,000 and 5,000 in the summer. Our dealer uses Motorcraft synthetic and changes the oil filter every time.
She get approx 13 to 14 pulling the trailer and up to 22 to 23 on a flat straight road at 55,
Mileage will drop to 20 to 21 at 65 to 70 mph with no trailer.
My dealer said don't baby her, stick your foot into her and let her run.
I just got a letter from Ford saying keep up on your oil changes and have the dealer check the coolant chemicals every year.
Watch for and use the best oil, filters and clean diesel fuel and you won't have problems.
We love this truck, it's our 1st diesel besides the tractor.
Malvern
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
JLG 1255 Telehandler (A53472)
JLG 1255...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
