Newbie CAT 1 / 2 linkage hydraulics question
   / Newbie CAT 1 / 2 linkage hydraulics question #1
Chris Wilson
Do any tractors have dual acting rams on the back linkage, so they can push down, as well as lift up? The reason I ask is if you had, for example, a post hole borer on the rear linkage, with a dual acting ram you could apply more load to the auger than that generated by the assemblies own weight. Just curious as to whether it's available, and if not, why not? :) Thanks.
   / Newbie CAT 1 / 2 linkage hydraulics question #2
I don't know this for a fact, but I think that the manufacturers don't want to take any weight away from the rear wheels and loose traction and the implements would have to be built a lot stronger so that they could hold the weight of the tractor, thus increasing the implement cost.:( All around bad deal, simpler and more cost effective to have single acting hydraulics. If you need down pressure for a PHD, they have hydraulic down pressure kits for about $500.
   / Newbie CAT 1 / 2 linkage hydraulics question #3
Some old Farmall letter series tractors had 3pt downforce (like the Super A)...
   / Newbie CAT 1 / 2 linkage hydraulics question #4
Belarus 250A - Stalin's revenge - has downpressure on the 3PH.
   / Newbie CAT 1 / 2 linkage hydraulics question #5
As you have seen.. MOST tractors don't have 3pt downforce.. -few- do.
soundguy
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
16ft 3in Box Blade (A51573)
16ft 3in Box Blade...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
