Newbi with HF Hitch Question
/ Newbi with HF Hitch Question #1
DraftHorse
Surprise, AZ
Kubota GL3130
I've been lurking on this site for just about a month now and am totally impressed with the quality and quantity of knowledge here.
It was due to this TBN that I first learned about the HF QA unit, which I went out the next day to the local HF store to see if they had any in stock. To my surprise, they had 7 in stock.
I had no issues with mounting it and using it. (will replace the bolts with pins though)
Now my question. I was looking at the Landpride QA unit and they recommend using a "thicking bushing" to make a tighter fit on the lower hooks. Thes "bushings" slide over the cat 1 pins and make then larger to 1.44 inches.
Would these be required for safer operation ore are the even really needed?
Thanks in advance:)
/ Newbi with HF Hitch Question #2
In my opinion the bushings are needed to keep the implement from bouncing all over the place. The hooks on the bottom of the QH are CAT 2 size.
If you have a TSC nearby, they sell CAT 1 to CAT 2 bushings at a very reasonable price.
Oh, and WELCOME TO TBN!:D
Makes sense. I've seen a lot of posts about people having the HF Hitch, albeit, having hook-up issues. Has anyone had to use the bushings on their Cat 1 implements ?
/ Newbi with HF Hitch Question #4
I still haven't looked at a quick attache system for 3 point. I like the punishment I guess. Works good, huh?
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
Progressive Liquid Nitrogen Applicator (A66285)
Progressive Liquid...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
2012 Ford F-150 Pickup Truck (A64194)
2012 Ford F-150...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
