Newbee in Town with oldee loader
   / Newbee in Town with oldee loader #1
Dcara
East of Dallas TX
Ford 2810, Komatsu D31S-16; White 2-105
Hi folks. I just joined this forum after finally getting my first machine (a Komatsu D31S-16 track loader, 1978 model). Its a small machine at only about 14000 lbs but I think it will do what I need done which is land clearing and digging a few more tanks. Last weekend I found about 30 minutes to play with it and pushed over a few old Bo-darks up to about 6 in diameter. In October 2007 I rented a JD455 loader for a couple weeks and cleared a couple acres of trees where I then dug a tank 13ft deep and 100ft in diameter. Anyway, I now want to find places (and/or learn how to find places) to get used parts for it. I need a different cap for the hydrolic tank. The one currently on it seems to fit but when I was bouncing along fluid would splash up onto the cap inside and then run down the inside of the cap onto the top of the tank outside where the arm rest is. Within my 30 minutes of use the top of the tank and part of the arm rest had a good bit of fluid on it from this. The local dealer wanted $60 for what looks like a 1960's vintage car gas cap. Certainly, I can find a used one cheaper, but where.
Other issues I have with it are:
1)I need to find the shop and O&M manuals for it at reasonable prices.
2)The right track is a little weaker in that it will stop spinning if I try to push an immovable object where as the left one will keep spinning. It has a power shift tranny but I don't know if the tracks are clutch or hydrostatic drives.
3)If I try to turn just a little right while pushing a pretty good load of trees it will start to turn and then the right track will stop completely and I have to let off the pedal and re-enage it before the same thing happens again. Suggestions please.
4)I need another lift pin on the bucket left side unless I weld a bolt on the current one to keep it from sliding out.
5)There is a disconnected electrical device on top of the fuel pump. I would like to find out what it is.
I'm looking forward to doing work on it, and with it. Any help and/or suggestion appreciated.
Thanks Cat Driver
Doug
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2016 John Deere 5055E 55HP Utility Tractor (A52377)
2016 John Deere...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
1990 UNKNOWN 16 T/A TRASH TRAILER (A53843)
1990 UNKNOWN 16...
