Newb troubleshooting?
   / Newb troubleshooting? #1
MarkMCM
Arlington, TX
MF 275
Drive motor of my mig seems to surge and feed speed vary and I can stop the motor by pinching the wire at the tip with my fingers.
Should I be able to stall the motor so easily?
   / Newb troubleshooting? #2
Guessing you have your drive rolls way way too tight. The wheels should slip. On making the motor stop, depends on the feed system but the short answer is no.
Will make sure about drive wheel. Just seems to stall motor much easier than my other welder.
   / Newb troubleshooting? #4
Which welder do you have there?
Lincoln 180HD that is probably 6 years old.
   / Newb troubleshooting? #6
I had much the same problem with my Lincoln WeldPak. The wire feed would surge. Replacing the liner solved the problem, it had a very slight kink in it.
   / Newb troubleshooting? #7
Pretty bullet proof machine. Swap liner and go a couple oversized like an 045 liner. Get you wire tension set so the drive rolls slip instead of stopping the motor and I bet you will be good to go.
   / Newb troubleshooting? #8
A worn contact tip can also do the old "slip and stick", and it takes ten seconds to change.
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2019 FORD F-250 SUPER DUTY (A52472)
2019 FORD F-250...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2019 Nissan Sentra Passenger Car (A51694)
2019 Nissan Sentra...
