New ZD21 Pro Maintenance Issues
   / New ZD21 Pro Maintenance Issues #1
Saxman
Bronze Member
Southern Illinois
L3830
I am going to be taking delivery of a new ZD21 shortly, I need some advice on motor oil. Do most of you use Kubota oil and filters? I was planing on using 15W40 Rotella like I use in my Powerstroke pickup engine. As for filters I was going to use Kubota filters in case of a engine problem but I think filters like NAPA gold are as good. Does the ZD have the same fluid capacities for the engine and hydraulics as tractors such as the BX2200? Any advice is appreciated
   / New ZD21 Pro Maintenance Issues #2
The Shell Rotella 15W40 will be a good choice. I personally use Kubota's filters. My 3130 oil filter is around $7.00 I believe. It will take between 4-6qts..
Thanks for the information, does anyone know the capacity of the hydraulic system on these units? How much super UDT will it take for a complete change?
   / New ZD21 Pro Maintenance Issues #4
saxman:
I don't think Kubota knows the capacities of any of their equipment. If you have a HST be prepared for a lot of oil to be drained.
I tried figuring the refill rates using the metrics and all that good stuff and I finally gave up because the HST and the engine oil pan take more than they say. I just use the dip sticks a lot and keep adding until I am full. I do run the engine for a few minutes after getting most of the fluids in...makes sure that the filters are full.
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
PALLET OF AIR CHISELS (A50854)
PALLET OF AIR...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2012 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2012 STEPHENS...
2021 Snake River 14K Dump Trailer (A49461)
2021 Snake River...
