New York Trailering Rules
   / New York Trailering Rules #1
1001WordsPhoto
Montgomery, NY
New Holland
I have a New Holland SubCompact tractor with a front bucket. I want to trailer it and drive it across town on local roads, no highways. I have a pickup truck and a trailer that are current in registrations and inspections and can handle the load. I am a private citizen moving equipment for noncommercial use. If I am not driving the tractor on the local roads, do I need any plates or permits? Thanks for the help.
   / New York Trailering Rules #2
:welcome:
   / New York Trailering Rules #4
If you are hauling a subcompact on a trailer, you don't really have to worry about anything but making sure its well tied down and the truck/trailer can handle the load...
Aaron Z
   / New York Trailering Rules #5
As long as your tow vehicle and trailer are registered and you're within the weigh limits you should be fine.
I remember many years ago there being "special commercial" plates that I used to see on tractors or other various equipment that would be driven on a public road, but I haven't seen that type of plate in years. Many of us NY residents have registered our trailers in Maine. In my case the fee went from $75 per year in NY to $99 for 5 years in Maine.
   / New York Trailering Rules #6
Hey JJZ,
DO tell me how this is legal! I am SO tired of New York State's "nannyism" (other than re: environmental and social issues) that I resent paying their (near highest) taxes.
Does one have to own property in Maine, to do this? If not, please regale me. I'm "all ears," as my dear, departed Grandpa was wont to say.
Fascinated.
My Hoe
   / New York Trailering Rules #8
I am not sure what you are asking here? Normally you should not need any special plates or permits just for moving your tractor around in NYS as long the trailer is rated for the combined weight of tractor/implements/equipments and weight of trailer. If your truck is rated to tow the trailer max weight, and you have tractor tied down properly with straps or chains ( I prefer chains). Also as long what ever is attached to tractor doesnt stick out wider then 9.5 ft and 4 ft past trailer - its legal. When tieing down tractor - pretend you are moving it commercially- 4 separate chains on tractor in X fashion and strap/chain on FEL and additional straps/chains on each implement. All hooks of straps/chains always looped inside of a pocket or frame and back up and hooked upright so the weight of hook is hooked upright so it less likely to fall off and the chain/strap is inside of strap/pocket prevents it flapping around dangerously if it comes unhooked. Do it this way will not get a closer look from local DOT but they dont seems to bother private owners anyway.
   / New York Trailering Rules #9
almost forgot -- in NYS - if towing more then 3500 lbs- gotta have brakes on trailer. Also if you have tandem axles then both axles must have brakes as per NYS.
Thank you all for the input. My trailer is a dual axle with brakes at each wheel, and is rated to care about double the tractor weight. Come spring time, I will be moving this back and forth to get yard work done at my family properties. Thank for the help.
Does anyone know if I can drive the tractor on the local roads? I need to install the triangle reflector and test all the lights, but do I need a plate for that? I can't find a tractor registration in the NYS DMV that isn't for "farm equipment". It would be easier if I owned a farm.
Again, thanks for the welcome and the help.
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Kubota RTV500 (A47384)
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
