new XJ2025H
/ new XJ2025H #1
DeliriumTremens
Cohutta
none currently
I never thought I'd end up with an LS. I have spent the better part of a couple weeks researching, test driving and spending an unreasonable amount of time learning about different tractors. I had found a tractor I liked, the Kioti CK2510H but hadn't found a dealer I wanted to deal with yet. (the first dealer ((not a LS dealer)) changed the agreement as I was getting ready to write a check. I eventually contacted a dealer 100miles away who convinced me to come talk to him (his price quote helped as well). After a 100 mile drive to talk and "test drive one of our LS models" I was hooked and left being the owner of a key, hat and an owner's manual with poor grammar. Thankfully I was armed with enough information from here and other sources to have some idea about the LS brand and made what I feel to be a decent deal. I just received word that the tractor is being delivered tomorrow (I don't have a trailer or else I would've already had it home). I'm looking forward to joining the LS family and will post pictures up when I get a chance. I'm sure with the small 6 acres I just bought I'll be involved in some shenanigans before you know it.
/ new XJ2025H #2
Congratulations on the machine. I take care of 6 acres of combined mowing, grooming horse rings and driveways, and snow removal with 24 hp just fine and you will be too
/ new XJ2025H #3
I hope you enjoy your LS as much as I have mine!
Yep, that manual is a hoot to read. Let's just say a little imagination is required.:laughing:
/ new XJ2025H #5
Congratulations. Being that I own a 2014 LS J2023 I hope you enjoy it as much as I have. Just 3 words of advice- LOAD YOUR TIRES. It is almost a must. I went w/Rimgard. It added an additional 320 lbs.
/ new XJ2025H #6
Congrats. Over 90 hours on mine and running good.
/ new XJ2025H
So i finally got some time on the tractor and cut about 4 acres of stuff similar to what is in the picture. The first few hours and began to think that the tractor wouldn't going to do the job as the bushhog wheel was continuously in the air or plowing through the dirt, but after some reading and adjusting the top link and rear wheel height I got a better cut and had a more enjoyable time. Once I get the ruts from the previous logging and some of the trees cut/trimmed my time and all the massive rocks moved my spent cutting should be markedly decreased (lets not forget when actual grasslike structures begin growing).
My only complaint at this time is the position control for the 3pt hitch. It would be nice to be able to set it to a specific level and forget about it. Otherwise so far, so good.
/ new XJ2025H #8
Thats a good looking tractor! i ended up buying a kioti ck2510 but this was a close 2nd for me. What do you mean by the position control on the 3pt?
/ new XJ2025H
I actually was sitting at the table to buy a Kioti CK2510hst but the dealer changed the price $1700 as I was pulling out the checkbook, said he had been quoting a gear price the whole time (despite me having 2 other dealers quoting the same price for the HST that I talked them down to). Anyway. The 3pt hitch on most tractors has a setting where you can adjust a screw to determine where the hitch goes down to. I think the kioti has this. This one has a 3pt that has a lever with up/down function, but returns to a neutral position, so it's pretty much a guess or turning around to look and see what height your implement is at. I'm sure someone can describe this better but that's about the gist of it.
DT
/ new XJ2025H #10
Yea I believe I know what your talking about. There is a slide screw I can adjust on the 3pt lever, I guess I've really never fooled with it much. I think the kioti and ls are pretty comparable tractors. I wouldn't mind having a xj2025 along with my ck2510 lol. Post some more pics!
/ new XJ2025H #11
Congrats on your new tractor!
/ new XJ2025H
I bought the tractor with 0.3hours, but was delivered with 3.0 :eek: now i've got it up to almost 16-17hours. I'm being much more proficient with it and enjoying it more each day, although some rocks require some coaxing to get in the bucket...... Now I need to start planning ahead for the first oil and filter change at the rate I'm going.
/ new XJ2025H #13
Pretty big rock for a little girl like that. Mine seemed to get a little smother and stronger when broken in a little- about 20 - 25 hrs.
/ new XJ2025H #14
Congrats! I've got a J2023 on 27 acres and havent been let down yet.
/ new XJ2025H #15
Congratulations on your new tractor. The LS 2025H was on my short list too. The one thing I wasn't sure I could get used to was that three point control arrangement. I much prefer position control (which they call it in there literature but they are incorrect). If you are innovative, I came up with a solution concept. Some sort of an indicator connected to the lift arms might work so you can move the hitch up and down to the same point each time. It's not position control but it beats visual on the implement each time. It would take some design engineering half the fun of a tractor is customizing it.
Good luck and have fun.
John
/ new XJ2025H #16
DT
I HATE those type of tactics. I am glad you walked away. Dont reward that type of behavior. You look like you ended up with an awesome LS tractor.
/ new XJ2025H #17
My dealer quoted me a price, then called and said he had made a mistake. Then quoted me a price about a grand lower. That pretty much made the 6' Rhino box blade free....at least the way women think it's free. So there ya go!
/ new XJ2025H #18
I've tried that logic with the woman: That anything taken off sticker price makes extra stuff free. Doesn't work for me too well.
/ new XJ2025H #19
That worked out for me, too, dstriplett. Saved almost $1000 over another quote, which nearly pays for the new rotary cutter. Mine is an accountant by profession, so she gets it.
Congrats on the new tractor, DT.
(APPROX,9) UNUSED KJ GALVANIZED WELDED WIRE MESH (A62131)
(APPROX,9) UNUSED...
Knapheide Service Bed (A61165)
Knapheide Service...
2018 Ford Escape AWD SUV (A61569)
2018 Ford Escape...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
240 Massey Ferguson Tractor (A61165)
240 Massey...
2022 John Deere Z920M Zero Turn (A63116)
2022 John Deere...
