New XJ2025 is here,,,?'s about oil filters,oil etc...
   / New XJ2025 is here,,,?'s about oil filters,oil etc... #1
cvcman
syracuse ny
john deere
Well I put 5 hrs on it brush hogging...did a fine job....4ft rotary mower,,,got the loader too...I notice it pukes a little gear oil out the front right axle breather.....and I notice the oil dip stick wants to keep coming part way out...what to do to fix these ???
Now it says for the 50 hr to chg engine oil and both tranny filters...I am not close to a dealer,,,where is a good place to but ll the filters ?? Does NAPA have a cross ???
Also where is a good place to get engine oil and what weight for yr round use ??
Its a fun machine !
   / New XJ2025 is here,,,?'s about oil filters,oil etc... #2
The dip stick is an easy fix. I fixed mine with a small tie down. dip stick.png
   / New XJ2025 is here,,,?'s about oil filters,oil etc... #3
you should be able to order the filters from your dealer, or online and get them shipped straight to you
   / New XJ2025 is here,,,?'s about oil filters,oil etc... #4
Here are my filter notes. I think the Zinga is Amazon, Messicks or my dealer depending for the LS/CNH oem filters which I use. Congrats of the new beast!
• Oil Filter, PN 40056451. have 50 hours 48010995 new CNH
• Fuel Filter, PN 40223960.
• Air Filter, PN 40049450. Service 50 hours
• Hydraulic Filter, PN 40220109. 50 hours
• HST Filter, PN 40195621. suction 50 hours ae-25 zinga
• LSTH400 oil to top filters
Wix Oil Filter- 57040 napa 1358
Wix Air Filter- 46449 napa 6449 kohler 2508302s
Wix Fuel Filter- 33830 napa 3830
Hst and hydraulic filters are switched according to the chart
API GL4 ISO VG 32/46 5.3 gallons SynTractor
API GL4 SAE 80W front axle 3 liters
Zinga ae-25 4 wide 6 tall 25 micron napa 1152 jd AT38431
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-3
   / New XJ2025 is here,,,?'s about oil filters,oil etc... #5
If crank case pressure is causing the dip stick to creap out i would check and see why the pollution crank case device was not sucking out the crank case blow by or is it something more serious. That is not normal in my openion.
   / New XJ2025 is here,,,?'s about oil filters,oil etc... #6
before I bought my XG3025, I watched EVERY video I could find on the 25 horse tractors. This is a known issue with the 2025, everyone seems to think it's more of a vibration thing than crankcase pressure. When I bought mine, they didn't even have a 2025 on the lot to look at, I was between the 3025 or the 3135, and my main determining factor, was payment range I wanted, but also not wanting to have to deal with the emissions stuff IE:regen
Unused Delta Crash...
2022 Adams CLC-1013 Conveyor - New (A53472)
2022 Adams...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A52576)
2020 CHEVROLET...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
