Dwight:
Thanks for the tip about Bela Fleck, I will without a doubt buy that CD just on that recommendation. I have heard him, but not with a careful enough ear. Thanks for clueing me in. I know a couple who routinely drive hours to see Bela Fleck and the Flecktones, so he's GOTTA be good. Looking forward to hearing that lick!
"Old Man" is on the album (album? wazzat?) "Harvest", a classic by Neil Young, recorded with the help of some of his friends - Steven Stills, Graham Nash, David Crosby, Linda Ronstadt, James Taylor, John Harris on piano, and the London Symphony Orchestra. I hope you do listen to it, and enjoy it as much as I do.
On the tire pressure thing - no, I would not recommend increasing your tire pressure A) over the manufacturer's recommended maximum pressure as indicated on the tire, B) to a pressure higher than that which will give your tire the proper functionality for the task(s) at hand (often a pressure less than "A"), or C) to a pressure that would appreciably increase the tire's rolling diameter to anywhere near that which would even begin (IMHO) to have any significant impact on the lead/lag ratio. Such a pressure would HAVE to be MUCH higher than "A". It's a tire, not a balloon. That is why I dismissed with extreme prejudice Kubota's suggestion that I do so. In fact, as much as I eschew the use of "negative adjectives", which I consider a form of attack, I am sorely tempted to dimiss their advice as "ridiculous".
Regarding "B" above, it is beneficial to use as low a pressure as possible that will still get the job done and not cause your tires undue hardship. For instance, the Michelin XM27 ag (radials) can (should be?) run at 9 psi in the rears, allowing maximum traction and footprint, while minimizing ground pressure.
Also, this </font><font color="blue" class="small">( (as my
L3130 warms up out front). )</font> brings to mind a very informative thread that I recommend to anyone who owns a diesel engine. Good stuff. Here's the link:
To idle or shut off - which is best?
It's not just about idling, it also gets into warmup practices. After reading the comments in it, I now warm up and idle much differently. (Warm up at higher speeds w/ gentle load, and idle faster at all times).
Lastly, a friend just walked into my shop and raved about a Bela Fleck collaboration with Edgar Maier (sp?) on cello, he says its GREAT. Maybe you've heard it? I'm about to.
Best wishes, John D.
