Treat the interior of the tubes like aircraft builders do.
Rust Protection
Protection For Welded Steel Fuselages
Traditionally, the interiors of tubular steel fuselages are shielded from rusting by a protective coating of linseed oil. After all welding has been completed, the tubing interiors are then flushed with hot linseed oil. The oil, heated to approximately 160°F. is forced into the tubular structure by squirting it in through the small holes previously drilled into the tubing. A small capacity trigger type oil pressure pump can works fine (see Figure 1).
The amount of hot linseed oil you introduce into the fuselage’s tubular structure should be measured before hand so you will be able to determine, later, that most of the excess hot linseed oil has been drained out after treatment.
Feeling for the warmth and coolness in various sections of tubing, as the hot oil is introduced, will give you some indication of the presence, or absence, of the heated oil.
Rotate the tubular fuselage as the hot linseed oil is being introduced to ensure its insides will be completely oil coated.
After two or three minutes, you can drain the excess oil. When you have determined that most of the oil has been drained out, plug each hole. Use short cadmium plated self-tapping screws to prevent moisture from re-entering the tubing and nullifying your rust-inhibiting oiling effort.
After your tubular structures and assemblies receive their hot linseed oil treatment and have been sealed, the entire tubular welded structure should be cleaned-preferably, sandblasted.
Aircraft Welding and Steel Tube Fabrication - Part 9
Rust Prevention
Preventing the rust on the insides of welded tubes is something that everybody knows is necessary, although not everybody does something about it (See Figure 5). Many tube fuselages are assembled in such a way that before the tubing is welded, holes are drilled at the intersections, inside each piece of tubing, so that oil can be poured in an inlet at one end of the longerons, and it will eventually find its way in to all of the tubing. In the past, this oil has been nothing more than boiled linseed oil, but now there are several commercially prepared oils that do the job even better.
CORROSION PROOFING OF LAND PLANES CONVERTED TO SEA PLANES
www.velocityxl.com/wiki/images/1/17/2r-ch6_13.pdf
c. Protect the interior of structural steel tubing. This may be done by air and watertight sealing or by flushing with hot linseed oil and plugging the openings.
