Price Check New Tractor Price... in the ballpark?
   / New Tractor Price... in the ballpark? #1
Trailblazer
Oregon City, OR
Kubota L3130HST
Hello, I'm a newbie looking at a Kubota 3130, partly based on what I've read in these forums. Got a quote on the configuration I've selected and wanted to see if the old hands on this forum think it's reasonable. Here it is:
L3130HST-F w/ ag. tires $14,795
LA723 Front Loader w/ 72" bucket $3,935
LandPride 72" box scraper $680
BushHog 6' rotary cutter $995
Total $20,405
I'd really appreciate your comments/opinions. Great forum!
   / New Tractor Price... in the ballpark? #2
You are looking at a great tractor. My 3130HST with turf tires was $14,500.. I think industrial tires cost the most, then turf, then ag.. Loaders run from $3500-4000.. Different areas of the country have different prices. West and east coast prices seem higher than the midwest from what I've read. Others will chip in on what they think as a lot of members have this tractor. I think they are fair prices but not as cheap as some have psoted in the past. Since you are buying 4 items, I would counter back an offer of $19-20,000 for everything and see where you end up. Good luck and welcome.
   / New Tractor Price... in the ballpark? #3
I was interested in the 3130 GST the best price after checking
8 local dealers was 3130 GST $13698.00
the LA 723 Loader with quick attach loader and quick attach on the
bucket ,along with the heavy duty bucket with teeth was
$3957.00
I know that HST is more but this may give you something to
go on
I ended up going with the 3830 GST and the same loader
it ended up costing me $1965.00 more for more horsepower
the loader stayed the same price
This dealer was in Virginia
   / New Tractor Price... in the ballpark? #4
Pricing sounds just about what I paid...Grand L3430 w/723 FEL...
One thought...I don't do a lot of "loading" with my bucket, more digging and lifting...so I convinced my dealer to swap the 72" bucket for the 60" and the Quick Attach mount...worked out to about the same money, and will give you a lot more breakout force and a little more lift capability /forums/images/graemlins/smile.gif plus the quick attach ease, speed and convenience!
GareyD
Thanks for your input - I'm getting a couple of competitive quotes. However, in speaking with other dealers, I'm now receiving conflicting advice.
One dealer strongly recommended filled tires to deal with my hills, while the first dealer recommended against filled tires. The first dealer said the calcium chloride (hope I'm remembering that right) used to fill tires can be corrosive and shorten tire life. Any thoughts on this?
Also the first dealer recommended the 6' bush hog, while the second said an L3130 might be overtaxed by that big of a deck on hills. I'd hate to find out that I bought attachments too big for the tractor. Should I downsize the cutter, or upsize the tractor?
Regarding the smaller loader, that sounds like a good idea. I'll probably be doing mostly loading with some digging, but the smaller bucket might give me more flexibility and lower expense for only a small cost in extra loading time.
Once again, thanks for your input.
   / New Tractor Price... in the ballpark? #6
</font><font color="blue" class="small">( One dealer strongly recommended filled tires to deal with my hills, while the first dealer recommended against filled tires. The first dealer said the calcium chloride (hope I'm remembering that right) used to fill tires can be corrosive and shorten tire life. Any thoughts on this?
Also the first dealer recommended the 6' bush hog, while the second said an L3130 might be overtaxed by that big of a deck on hills. I'd hate to find out that I bought attachments too big for the tractor. Should I downsize the cutter, or upsize the tractor? )</font>
I can comment on some of your post.
First, if you have concerns about tractor stability, you can bank on the fact that filled tires (= a lower center of gravity) will help somewhat, and not increase the risk of a roll-over. That being said, common sense will be needed (and perhaps a fully functioning tilt meter) for safer operation. Tractor tires are being filled with MANY things these days so again, it's a common sense decision that is yours and your alone.
Tire Fills:
1. Calcium - a common choice but can be pricey
2. Foam - totally safe, but not terribly effective from a weight gain perspective
3. Antifreeze/Water - also common but there are complaints of an ecological nature i.e. a spill would result in some soil contamination
4. Windshield Wiper Fluid - same as 3 above perhaps to a lesser degree - I believe the wiper fluid is alcohol based ...
5. Water - bad - can both rust and freeze and may damage your tires from the inside
With regard to the 6 foot brush cutter, the L3130 will work that device just fine on flat or mildy rolling terrain. Based on the posts of others, it sure sounds like it will also pull it on hilly terrain also.
However, the term "hilly terrain" is subjective. How hilly? What are the slope angles and lengths? This too is a common sense requirment and the best way to answer this question would be to try and have a machine w/ implement brought out to your parcel for some test runs. You may get a lot of testimonials like "my L31010 pulls a 7' hog up and down my grades all day!" ... but it is relelvant/subjective and there can be no substitute for using the machines and cutters on the actual lands it will be used on.
If ya got 1 or 2 big hills that make the thing groan a lil but acres of flat runs, so what. A good CUT is overengineered and should be able to weather some moderate strain to it's components, again, all within good common sense.
   / New Tractor Price... in the ballpark? #7
Dap......... you forgot to list "beet juice" or Rim Guard as it is known by its proper name as a alternative. It isn't corrosive and it is safe for the environment. It combines the best of both worlds..... This is what the industry is moving towards.....
Beet Juice - has it been around long enough for most dealers to stock and use it? I think I'm going to want the tires filled, but I don't want to shorten tire life or spill poison on my land. The valley in back of my property has some very steep spots and a low center of gravity would help.
   / New Tractor Price... in the ballpark? #9
Hi Trailblaser,
I live on a very steep slope of Chehalem Mountain between Sherwood and Newberg and I do not fill my tires. The counter balance I have is the heavy duty front bucket that I never take off used with some kind of rear attachment like my Land Pride.
I am also dodging (when ever possible-I always get some road kills every year..) Asian Pear trees and newly planted cherry trees. I makes for a challenging drive!
After my dealer visited my land (he lives in Wilsonville) he told me that he did not believe it was necessary to fill the tires.
I am glad he advised me not to do so because I would have had ruts in the back yard that my wife would never let me live down.
FYI-I purchased the R4s so that I could drive on pavement and move rock. They are the only way to go.
Have fun!
   / New Tractor Price... in the ballpark? #10
Here's the web page for Rim Guard. Maybe they can direct you to a local dealer.
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
1988 Butler Equipment Trailer (A50515)
1988 Butler...
1995 1063 Corn Head (A50514)
1995 1063 Corn...
(4) 12' Steel Gates (A50515)
(4) 12' Steel...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
RING 3 STARTS HERE @ 9:30 AM (A51244)
RING 3 STARTS HERE...
