new tractor oil changes
   / new tractor oil changes #1
DAVEN
Washington state
jinma 204
I have just bought a new Jinma 224 I want to change all the oils after i do a run-in What should i use?
   / new tractor oil changes #2
What's the owner's manual say to use?
The manual talks about No. 20 Diesel engins oil in the engine. Trans box No.40 Diesel engine oil. Front and rear Axels also No. 40 Diesel engine oil. I'm not a idiot or anything but what is No. 30 and No. 40 Diesel engine oil? Straight grade engine oil recommended for diesels?
Should't the gear box have Gear oil? and /or axels use 80-90 or 80-140 rear end lube? /forums/images/graemlins/confused.gif
   / new tractor oil changes #4
I've never seen oil recommendations like that. Hopefully, someone else has.
   / new tractor oil changes #5
DAVEN,
Your profile does not indicate where you live so giving a correct answer is difficult. In the US there are no "No. 30 or No. 40" motor oil classifications. In the US there is 30 and 40 weight motor oil that is certified by it's API designation as meeting the requirements for diesel engines.
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
3.5 x 8 Hydraulic Cylinder (A50515)
3.5 x 8 Hydraulic...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
Whisperwatt 45KW Towable Generator (RUNS) (A50774)
Whisperwatt 45KW...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2012 Ford Edge SUV (A50324)
2012 Ford Edge SUV...
