New Tractor Home - Construction
   / New Tractor Home - Construction #1
Knight9
Veteran Member
Alberta
Kubota B2410 with turfs
Well it is slowly coming together. Last year I whipped up a 12' x 16' shed to store the tractor in. It worked well, but I needed more room for a skidoo, implements and a workshop. Decided to build a double detached garage.
This is a brief photo journal to date. This first shot is not very exciting. Just the staked out dirt area the garage is going into. The dimension are going to be 26' x 28'. This is the largest size the county I live in will allow as a floating slab without a full frost footing engineered foundation.
Kevin
Here is a shot of the concrete slab after it was poured. It is 5" thick reinforced with rebar in an 18" grid. They did a really nice job on the finish as well.
Kevin
This was after two walls were raised and the other built although they were still laying down. I did all the framing myself and had friend/family help me stand them up. Made a difference even having 2 walls up. Started to feel like some progress.
Kevin
This evening we raised the two walls that were laying down. Trusses are supposed to be delivered tomorrow. That will be the next challenge.
I'm happy with how it is turning out although I'm sure many of you will point out how I'll wish it was bigger and fill it too soon /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif I agree but there is a point where $$$ has to make the decision.
Kevin
   / New Tractor Home - Construction #5
You can just build another one beside it if it gets filled.
Looks like a great job.
   / New Tractor Home - Construction #6
Great job Kevin.
It's nice to see an outbuilding being built out of wood. Around here, everyone's going to metal. The south of the border steel is just too cheap to do otherwise. I built mine out of steel, but I sure like the looks of wood better. What are you going to use on the outside walls?
And keep us posted as the job proceeds.
Dave
Hi Dave,
In our area here, steel is actually more expensive although only slightly. I like dealing with wood more anyway. I'm familiar with it and know how to build with it. Don't know anything about building with steel /w3tcompact/icons/blush.gif.
The exterior will be clad with vinyl siding and the roof will have asphalt shingles....both to match the <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/35-149063-NewLawnTwo.jpg>house</A>
I will certainly keep this thread up to date as we progress.
Kevin
Been a long time coming with an update. Garage is up and shingled. This is all I'll do until the spring. Electrical is all done with the exception of exterior lights (wiring is ready just need to pick up fixtures).
Kevin
Second shot from the side.
Kevin
Final shot of other side of garage.
Kevin
220 bu Gravity Wagon (A50515)
220 bu Gravity...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
Gladiator 12-16.5 Tires (A50322)
Gladiator 12-16.5...
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
