New tractor being delivered, now what
   / New tractor being delivered, now what #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
New tractor (XG3140H TLB) being delivered tuesday, any recommendations on some things to do to it before using/abusing, just looking for ideas as to do upon delivery, obviously look it all over good, check bolts and make sure everything is tight, i may even throw a coat of wax on it to help keep it clean and clean easier, i noticed on my previous LS some hydrailulic hoses rubbed on frame in certain spots so do some preventative maintenance there, just looking for ideas if some of you guys look back and said i wish i would of done this first, thanks
   / New tractor being delivered, now what #2
You have a new tractor but by your post - you are not a new tractor owner. So - my recommendations are not quite as critical. Get a copy of your Operators manual - prior to delivery - read it cover to cover and then read it again.
On your new tractor - the word is --- Trust but verify. Go over the entire tractor - tip of nose to end of tail - check EVERY nut & bolt for tightness. Grab your grease gun - grease every zerk from tip of nose to end of tail. Check engine oil level, check hydraulic oil level, check engine coolant level. Relax - enjoy.
Thanks, yes this is actually my 5th tractor but first brand new one, maintenance wise i should be set but i think i may upgrade to a battery grease gun and a lock n lube tip,, one thing i may also do is get a piranha tooth bar to just help protect/maintain the cutting edge and also help with digging in
   / New tractor being delivered, now what #4
Take pictures, it will be looking it's best. Check tire pressure, sometimes they are set at maximum psi so they transport better (less bounce).
   / New tractor being delivered, now what #5
Hey - just three weeks ago I splurged and got a DeWalt cordless grease gun. Put my Lock 'N Lube tip on it. Greasing is a lot easier and not quite as messy now - lots quicker also.
I found the two step approach to greasing works a lot better for me. I don't come out looking like a grease monkey. First I go around and clean every grease zerk - Then I go around with the grease gun. Makes for a cleaner operation.
   / New tractor being delivered, now what #6
The OP should have an extra tube of grease for the first lube. Many of the grease cavities will not be filled so they take much more before it squeezes out. Also, when the tractor is new, it is the best time to familiarize yourself on zerk locations because you can SEE them.
   / New tractor being delivered, now what #8
   / New tractor being delivered, now what #9
He didn't mention at the time but he did mention lubing all the pivot balls just before that. And a few mins later you can see the one you mentioned has been sprayed. Probably just an editing error. But it does look pretty dry at the point you mention.
   / New tractor being delivered, now what #10
Ha! Your right....I missed it. I do think the video is a good idea and he does a good job moving along.
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52576)
2018 KENWORTH T680...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2018 Gatormade 20+5 Gooseneck Trailer (A53472)
2018 Gatormade...
Toro Mower (A50324)
Toro Mower (A50324)
