New tractor and I already have a boo boo
   / New tractor and I already have a boo boo #1
muddpuppy01
Groveland, Fl
LS XG 3032
Just received my new XG 3032 today and not even 3.5 hours on it and I manage to poke a hole in my front tire with a piece of glass. Should I put plug in take it or take it to a tire shop to have a patch installed on the inside? Anyone know the PSI for the front tire?
   / New tractor and I already have a boo boo #2
The max PSI rating should be listed on the tire. Most tractors run at the max inflation pressure of the tire, but the owner's manual may have additional information.
Can't advise you about the repair without seeing the damage and location of the damage. But I have fixed a lot of equipment tires with plugs and never had issues. The only place they won't work is for cuts or slashes. It has to be a point puncture for a plug to be used.
the puncture is in the tread between the lugs, The piece of glass was maybe 1/4" at the widest portion which was not in the tire, the piece of glass went to a point total length was maybe 1/4" long as well.
   / New tractor and I already have a boo boo #4
Yeah, I'd plug that no worries. The reamer opens up and rounds out the hole anyhow. Of all the things you could do to a new tractor, this one isn't too bad. No paint or bodywork needed!!
   / New tractor and I already have a boo boo #5
Actually had a sharp stick go through my front tire between 2 lugs. Patch wouldn't hold air. Tire shop put in inner tube. Seems to work fine.
   / New tractor and I already have a boo boo #6
I would take it in and have a heat patch put in from the inside but that's just me and decades of paying attention.
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
John Deere turbo 6620 Combine with head (A52128)
John Deere turbo...
71062 (A49346)
71062 (A49346)
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
