Will_C
Veteran Member
- Joined
- May 24, 2002
- Messages
- 1,778
- Location
- Upstate N.Y.
- Tractor
- Kubota L3560, Toro 52" and 60" ZTRs, Kubota RTV 900
I just bought a new Toyota Tundra, Access Cab, 4x4, V-8 engine, automatic transmission. This is the first vehicle I have ever owned (besides a couple of junkers when I was a kid) with an automatic transmission. Reviewing the literature, I notice the dealer recommends changing the transmission fluid every 15,000 miles. I know some of these dealer recommended services are money-makers for them. The owner's manual calls for changing every 60,000 miles if used for towing, and does not call for any changes if not, just "inspection" at 60,000 miles. Toyota also calls for changing differential oil every 15,000 miles if used for towing.
I will only be towing a light load occasionally with this truck ( my BX 2200, 10 miles a week in the summer) so I don't think that the towing recommendation applies to me. I do maintain my vehicles, having traded a 1996 Tacoma in on the Tundra. That truck had 128,000 miles on it with no components replaced, not a thing mechanically wrong with it. I never changed the manual transmission oil or differential oil on that truck (Tacoma.)
What should I plan for maintenance on the Tundra? What do all of you do to maintain an automatic transmission? I don't mind doing what should be done, but I don't want to throw money around needlessly, either.
Thanks,
Will
P.S. I have heard that changing the transmission fluid really is not the best thing, that the transmission should be "power flushed?" if you do decide to change fluid. Any thoughts on this?
Thanks,
Will
