I actually found one rust hole that is about the size of a half dolalr.. it has been sanded down and plugged with a gob of bondo.. the owner didn't even conture the bondo.. just painted the lump! it's at the usual rust out places on the rowcrops.. the bottom of a dogleg just above wher ethe lil aluminum piece bolts it to the front bolster. I will cut/stitch in a new piece of metal.. that's a -0- problem issue.
my first priority is to get the hyds working and make her steer without needing popeye arms.. after that I forsee a new alternator, rebuilt start with new drive.. some new gauges, and a rewire, plus a new start switch, solenoid, ignition switch and choke linkage, plus all the gooey stuff in the sumps.
One rim has a rust hole around the tube valve stem that is eventually gonna need repairing.. i may actually just run it till the old tube lets go and then fix it when it is broke down to do the tubes.
soundguy
