New to me ZD326: left gas tank runs fine; right tank sputters and dies
   / New to me ZD326: left gas tank runs fine; right tank sputters and dies #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
Like the thread title states: My ZD runs fine off the left tank but not the right. I can literally turn the engine on and off simply by switching from one tank to the other.
And I just filled both tanks! :banghead:
So, I *assume* that the intake for the right tank is clogged or stopped up. So it would be a matter of siphoning the tank mostly dry, then blowing out the lines from the valve - or is there an easier way or other failure mode I'm not thinking of?
Thanks,
   / New to me ZD326: left gas tank runs fine; right tank sputters and dies #2
Not sure, but i'd be looking for the gas line and disconnect it and see if anything comes out of it first. If so, follow it down stream towards the engine. If not, let it drain in a can. My last 2 machines had a valve inline, near the filter. Is it on?
Pete, the ZD uses two tanks on each side of the machine, that are tied together with a simple valve. One side for the right, the other for the left. The filter is downstream of that/ If I could turn the ZD figure into a pic that shows the fuel setup, I would, but I'm not that smart, at least not right now.
The problem is definitely on the right side. I *assume* it's with the right side tank inlet, but wanted to know if there are other options/failure modes that I've missed.
Thanks,
   / New to me ZD326: left gas tank runs fine; right tank sputters and dies #4
You can pull the hose that goes to the valve out of the tank, it's on the top. Just a rubber gourmet holds it in. Bet your find something in that line, perhaps on the end of the pickup. If nothing on the pickup, take it loose at the valve and blow it out.
I had similiar issue with left tank. Pulled the line from the top of the tank, big black ant stuck in the intake. Put it back ok for awhile, then it happen again, another big black ant. After that it was ok. Don't know if I was the one that allow those ants in there....but I doubt it. Think they got in there when the tank was dry at the factory or the dealer.
K, good to know JC. Thanks!
   / New to me ZD326: left gas tank runs fine; right tank sputters and dies #6
I have the ZD 331 and had a problem with the left tank. Took the tank off and found some dirt blocking the inlet to the fuel line. Blew it out and problem solved
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2021 Fendt 1050 Vario Tractor (A53342)
2021 Fendt 1050...
