New to the forum and to diesels. Just bought a Mitsubishi MT 180. It has the K3C engine. It hasn't been running for a while though I don't know how long. Seller swears it's a good runner. We'll see. I topped off the fuel tank on the trip back though maybe it should all be drained. I thought diesel lasted longer than gasoline. Downloaded the operator's manual which I found in a post here. The manual has instructions for bleeding the fuel system. Opened the two screws by the filter and they both had straight fuel come out/no air. It's got straight fuel at the inlent to the pump. Cracked the injector lines and cranked it and had fuel drizzle out the front two but not the rear. At least not yet. Need to charge the battery as it's cranking slow now. I did put a tablespoon of oil down the intake. Engine oil is blackstrap mollasses but I was hoping to get it running and warm it up just a little before draining. The key switch has "heat" position when turned left which puts power to the glow plugs. Supposed to do that for about 5 seconds when it's cold out. 20 degrees F today. Unfortunately the key won't turn left so until I get a chance to take the ign switch out and maybe apart, I guess I'll have to jump power to the glow plugs. 12 volts + to the terminals on those?
Is there some major difference between a K3C and a K3C-13MT. ngine has a sticker on the valve cover with K3C-13MT. I saw one parts site that had both listed with plenty avalable for the K3C and almost nothing for the K3C-13MT so that worries me a bit. Seems these engines are used in other things like fork lifts and mowers. Any good sorces for parts out there?
Any general advice for getting this thing running in cold weather considering it hasn't been running in a while? It's got a block heater but I guess it's not working. I had it plugged in for a couple of hours and that spot on the block is 18 degrees F just like the rest of it. Don't have a heated shop but I might be able to tent it with a heater.
Thanks, John
Thanks, John
