jcummins
Veteran Member
- Joined
- Jan 14, 2007
- Messages
- 1,637
- Location
- Creal Springs, IL
- Tractor
- Kubota M7040, F3680, Mule Pro Fxt
If any of you have seen any of my post asking questions on the F series, you know I've been interested in getting one for some time. Finally traded my ZD326 for an F3680, 72" side discharge deck. Reasons I wanted the F, over the ZD....mowing around ponds, hillsides, wet areas. Today, didn't mow the yard, but did mow some areas I mow every other mowing, and also into areas, the ZD wouldn't go. I've got some questions for other F owners, and a recommendation to Kubota on the controls....so read on.
It took me 5 freaking minutes and STUCK IT.
That area was untouchable with the ZD. I drive the JD Gator thru there all the time in 2wd, so thought the F3680, 4wd would go through it. NOT. The obvious problem, the tires. SO...found that limitation real quick.
High grass mowing...better than the ZD, but still short of what I had hoped for.
In fairness, another pass cleaned it up. Some of that darker shade of grass was up to my should in the seat, so it was longggg. You can see the results of second pass, since I made a couple of passes uphill from that last cut.
Impressions:
Cut quality, believe the ZD is a tad better, in the general yard, judgement out. I need to mow the whole yard before saying for sure. The ZD would do a lot worse in that really tall stuff.
Hillsides....the rear end does slide down hill, but is controllable, making it crab a little but much better than the ZD. But I was expecting to do a little better.
Out front deck...HUGE improvement over the ZD. Edges of creeks etc, I can nudge the deck up and just run the wheels to the edge, then back up.
Speed...it's FAST, MUCH faster than the ZD.
Ride...MUCH better than the ZD. The ZD feels choppy compared to the F3680. I can run this F faster and not get as beat to death.
Hydraulic whine...much louder than the ZD. Don't like that.
Low range. I thought why would a mower have a low range. Well I found out. Dang thing TO fast in slow trimming areas etc. Found I needed to use low range to be able to control it better. AND, it really tall grass, low range works better.
Questions and a Kubota recommendation:
How does everyone else handle this HST go pedal? I'm sure I'll get more accustom to it, but I find the pedal a bit awkward. If I'm doing fine/slower forward/back I tend to want my foot and heel on the whole pedal to toggle back/forth. But that's not comfortable to me. Put my heel back on the floor, when just mowing. My recommendation to Kubota...is have ONE push pedal. The gas lever on the side of the steering column, should be a shuttle forward/backward and the HST pedal you just push for power...but not for reversing the mower. Maybe that's habits with the shuttle shift on my M7040....but it would make the right foot far more comfortable in operating the mower.
Tires...given how quickly I got it stuck, could/would a more knobby tire work better. I found tire spin on the big tires when making turns. Wasn't expecting to see that. Given that, I suspect a more aggressive tire would tear the lawn, but obviously a disappointment that I got it stuck so darn quick.
Quick steering. I'll get use to it, and I expected the rear steer would feel the way it does. But, boyee is it quick. You can really jerk that rear around. You can easily over steer. Steering knob? I like them and have had them on every mower/tractor I've ever had that has a steering wheel. How about other F owners?
The deck size alone.....then add in the speed.....this mower is going to cut into my seat time in mowing.
Am I happy I traded? YES! YES!
Impressions:
