jeepcoma
Hi all, first let me say this site has been great, I've learned a lot already searching through the archives and decided to sign up.
I just picked up a non-functional LX178. Owner wanted it gone because it's shooting gas onto the exhaust. It started and ran for the quick drive up on the back of the trailer, no idea how many hours are on it (it's a '92 model), but for that pesky stream of gasoline onto hot parts. I'm not sure if I will keep it at this point, I have a pretty small lawn and have no problem mowing it with a push-mower, but I wanted something to speed up bagging in the fall after discovering how great it was by borrowing a leaf bagging tractor last season. I'd like to get it working as cheaply as possible, to try mowing with it once or twice and give it a chance to win my heart, then decide to either sell it or actually spend money on it to get it tip-top.
After removing the cover and poking around, it was clear there were mice living under the hood and I was hoping it was just a chewed fuel line. My luck doesn't run so good so it was fuel spraying from the weep hole on the fuel pump. After searching the internet, it turns out this is a pretty common problem with the original pumps for these vertical Kawi engines. And holy sticker shock batman, dealer wants $150 for a new upgraded fuel pump (AM132715)!! Best I've found so far is ~$120 which is crazy , I found a reference on another site to JD discounting the pumps down to $32.75, but if it was true back then it's certainly not the case now. Seems like a major safety issue to me so I'll shell out the money if I have to, but does anyone know of a better source, or have a spare lying around for sale?
Alternatively, can these be fixed? I removed the unit and was playing with it on the bench (ok, in the kitchen sink) trying to see how it worked. It seemed like if I used "normal" hand pressure to operate the pump, it worked just fine, but if I really gave it a good blast that's when fluid would come out the weep hole. Sounds like a torn diaphragm but I would probably have to destroy the pump to take it apart, it looks like the cover is sealed on by the lip pressed around the outside. Anyone take these apart before? Anyway, even if I did fix it, I would be stuck with a fuel pump that will again spray fuel onto the exhaust when it fails; the new upgraded design with a fitting to hook a line onto seems a worthwhile upgrade. Mostly though I'd just like to see how this tractor works out before decided to put a bunch of money into it.
The muffler has basically rotted and split in half, the big canister is just hanging by a few pieces of rust and ready to fall off after one good bump (actually surprised it survived the trip on the trailer). Sticker shock continues (beginning to see why they paint them green) with a list price of $255! Oh well, I'm used to mowing with earplugs anyway. A used replacement part seems a good alternative, if I can find one.
Cosmetically, everything has mostly faded away, so I don't have a clue what buttons and knobs do what. I figured out how to start it and the parking break, but when I pulled a knob that might be the PTO engagement, the engine just stalled out. I'll need to check if the blades are frozen, seat safety switch is bad, and other things? There were some wires cut under the hood, but I think it's just for the headlights (since I found those under the seat). I bought the original manual and service manual CD so I'll start figuring this stuff out once they arrive.
I did replace the fuel lines, coolant lines, spark plugs so far, and wow it starts right up now and purrs like a kitten. I'm kind of disappointed I don't need to rebuild the carb, and I didn't even have to tinker with it. Maybe there is something to the JD name after all...
