Tires new tires - old b7100d
   / new tires - old b7100d #1
Anonymous Poster
Epic Contributor
I've had my '80 b7100d for a few months now and have been lurking here and learning alot. The rear r-1 tires are toast and I'm going to order new ones asap. I read in an old post by Kevin, that his b7100 used 6-12's on the front and 7-16's on the rear, mine has usable 6-12's on the front and 8-16's on the rear, which are worn down to almost no tread at all, and are very dry rotted. I have experienced the 4-wheel drive wind-up/bind-up that many have discussed here before.
My question is, Which size rear tire (r-1's) is the correct size?
   / new tires - old b7100d #2
The only way to know for sure is to measure the roll-out on the fronts versus the rear. You might also be able to just measure the circumference of the tires and compare that to the rotation ratio. This is a sure case of "your mileage may vary"...
The GlueGuy
   / new tires - old b7100d #3
I think that "Kevin" referred to me (Kelvin). I'll have to go back and check that old post when I get a chance.
My B5100/B6100/B7100 owner's manual say that the 7-16 is used on the rear of the B6100D and B6100E and that 8-16 tires are used on the rear of the B7100D (like your tractor has). So it looks like you have the correct tire size on your B7100D.
Hope this helps,
Kelvin
I have a 82' B7100d and I run 6-12 on the front and 8-16 on the back with no problem.
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
