New tenents
   / New tenents #1
Mike_Kanzer
Chester county, PA
Kubota L3830 HST, JD Gator 855D
I was cleaning up my pull behind manure spreader and found this when I opened up the side that houses the gear box. 5 mice total and packed with nesting material. I reversed the hose on my shop vac and blew them all out into the cold!
   / New tenents #2
Now they will be able to build a nest under your truck seat.
   / New tenents #4
Why not use the shop vac to capture them, then let them go someplace a long way from barn or house? Or sprinkle a little Decon near the nest and let that take care of 'em. Otherwise, they'll just get into more mischief...
   / New tenents #5
Those mice look dry . . . so does that chain.
   / New tenents #6
oil of peppermint and moth balls.....but I found moths don't like this...:)
2017 Vermeer BC1800XL Towable Brush Chipper (A55851)
2017 Vermeer...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
Trac Vac PT Lawn Vacuum (A56469)
Trac Vac PT Lawn...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2018 GENERAC MLT6SM-STD3 LIGHT PLANT / GENERATOR (A52707)
2018 GENERAC...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
