New TC24DA has no power help!!!
   / New TC24DA has no power help!!! #1
bebop86
NJ
hey just picked up a new TC24Da it feels like it has very little power-At what RPM do you guys run yours at?? Even when I go up a very little slope it seems to need more power- I will call my dealer but he is closed- What am i doing wrong??-Brake is not on-thanks,gary /forums/images/graemlins/confused.gif
   / New TC24DA has no power help!!! #2
RPM guides:
Running around the flat yard, with no place to go in a hurry - 1600-1800 rpm.
Time to get back to the house for lunch - 2200 rpm.
Climbing my 20% grade out back with the mower - 2400 rpm.
Showing that chlorophyll who's boss with the mower in thick grass - full throttle.
Getting the job done, in the sun, out at the farm - priceless.
Biggest mistakes of new HST owners:
Running too low RPM.
Trying to climb hills in higher gears rather than I-Low
Using the HST pedal as a gas pedal. The more you push it, the lower the torque to the wheels. Climbing hills will take rpms, low gear, and the smallest touch on the HST pedal.
Let us know how it works out for you. Wear hearing protectors, and soon that diesel whine, that seems too fast and high at first, will be music to your ears.
   / New TC24DA has no power help!!! #3
Just let up on that pedal and it will climb any hill. /forums/images/graemlins/wink.gif
   / New TC24DA has no power help!!! #5
I have a new TC40DA and had exactly the same experience. You can read about it here . Amazingly, followed the advice and I couldn't believe the power. I had it figured out in a few minutes and love the HST /forums/images/graemlins/grin.gif.
   / New TC24DA has no power help!!! #6
Bebop, I've got a new TC24DA too and had the exact same problem...everything the guys above said is true. It's not like a car, where you can floor it and go faster. Put 'er in low gear with just a little pedal and she'll climb a mountain, so long as there's enough traction. /forums/images/graemlins/blush.gif
   / New TC24DA has no power help!!! #7
DocHeb said it all better than anyone I've seen every say it. I've got a TC24 and a couple very steep hills. I'm amazed at how much power the tractor actually has! New tractor owners, especially those with HST transmissions often make a couple mistakes. The RPMs are often run way too low, these engines are designed to run all day every day at full PTO speed, and that is up near the very top of the RPM range, there is a governor on most of the little diesel engies to prevent running them too high. Another mistake is trying to climb hills in high range, they are not designed for that, the TC24 is only a 2 range machine, shift it into Low range. And as has been stated 1000+ times here on TBN the HST pedal is not like a car accelerator, but it is common to think of it as such. The HST pedal is really like a gear selector in a car. Barely touch it an you are in the equavalent of 1st gear, within the given range (High or Low) you will have the most torque available at this point. As you slow push down on the HST the torque (pulling power) decreases but the speed increases just as if you had shifted to 2nd, 3rd or 4th gear. Push it to the floor and you are in the equavalent of "overdrive" in a car, lots of speed but with minimal torque so only good when running on flat ground.
   / New TC24DA has no power help!!! #8
bebop86,
Something that I don't think any has mentioned, it could be a hydraulic quick disconnect that has come loose. When they do, it is amazing how sluggish a tractor will run. I would say to check all of them, it is sometimes had to tell if they are loose just by looking.
   / New TC24DA has no power help!!! #9
Hey Gary, you've claimed your 'dog won't hunt'. What's the scoop?
   / New TC24DA has no power help!!! #10
Gary,
I have been around tractors since I was 10. Now I am fifty almost and when I got my TC21D I had the same mistake most have. I think of the hydro pedal as a gas pedal and it is not. Now I have a TC29D and I have three ranges so it helps a bit having a mid range for an all around range. But your 24 I think only has two ranges so doing most of your yard work you have to be in the low range and the high should only be used on the road. And in low you should be able to do anything, just remember to let up on your pedal.
murph
2015 Nissan Frontier SV 4x4 Pickup Truck (A50323)
2015 Nissan...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
1999 Toyota Camry XLE Sedan (A50324)
1999 Toyota Camry...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
