new stronger grapple project
   / new stronger grapple project #1
2310 guy
Bronze Member
BI, BC, Canada
MF 2310
The last grapple i made ended up bending and twisting after I welded the gusits(sp) in. All the heat and my turnint the vise ended up totally twisting my grapple. Thats what happen when you use thin steel. A blessing in disguise.
I started a whole new grapple today with thick steel... no of this 3/16th baby metal. Everthing is 3/8" or 1/2":D also I'm using angle iron because its easy and strong.
Here are the pivot points.
The main platform, this is going to bolt to the top of the bucket. Not the side like before.
The pivot points before I tack weld them.
This going to be the pivoting end of the grapple teeth/arm
And here it is with a couple bronze bushings. Its a good fit.
Teeth/arms in the mounts.
welded into place.
Thats all I did today.
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
1998 Spartan Mountain Master 40FT Class A Motorhome (A50324)
1998 Spartan...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
