Oil & Fuel New Source, Oil for Kubota
   / New Source, Oil for Kubota #1
jimainiac
Platinum Member
Colebrook, N.H.
Kubota L3830HST
On a trip to WallyMart the other day, I was surprised to see Rotella-T 10-30 oil on the shelf next to the 15-40. Our L3830 owner's manual calls for 10-30 oil, and the only place I was able to get it was the Kubota dealer, Kubota brand oil. Even the local auto parts stores only had diesel oil in the 15-40 variety. Actually, I have used the Rotella 15-40 in the summer, but I thought I should use the the 10-30 in the winter.
I know I could have posted this in the lubricants section, but it's particular to our Kubota. I don't know what weight other brands and models call for. I've always used 15-40 in our old Kubota.
   / New Source, Oil for Kubota #2
You might check on the diesel specs for R 10-30 I have been told this grade is not diesel grade. you might inquire at their site. bb
   / New Source, Oil for Kubota #3
I never knew this. I just assumed all diesel engines used 15w40. do u think this is bad for my Kubota?
   / New Source, Oil for Kubota #4
Rotella T 10W/30 is a diesel engine oil and meets all current API spec's for diesel engines.
It will be fine to use Kubota. Some use 10W/30, others use 15W/40. If it calls for 10W/30 in the manual in your temperature range then that is what I would use.
   / New Source, Oil for Kubota #5
Kubota generally recommends 10w30 in its manuals and for most of us it is impossible to find. I looked at Walmart, auto parts stores, TSC, Northern Tool, etc. 15w40 is the most common weight available. This has been discussed a lot. General concensus is 15w40 is just fine and Kubota even sells a Kubota branded 15w40.
   / New Source, Oil for Kubota #6
Oil for diesels come in a variety of grades. In Canada Petro Canada actually produces a 0W30 oil with all of the diesel specs. As was indicated 10W30 is not uncommon.
The colder the temperature the better the lower grades.
Some engine manufacturers had a sliding scale for the use of the various grades.
I saw a test of the different grades each brought down to -10 - then they poured the various oils out of the container. 0W30 had poured a substantial amount of oil in a minute, 15W40 was still in the formation of a droplet still at the pour spout - none of the oil had started to pour.
The demo was what happened at start up of an engine at that temperature. Since then I have always used the lower grades in the colder weather.
Garth
   / New Source, Oil for Kubota #7
I also just found the Rotella 10-30 at Wal-Mart so figured they discovered a lot of diesel owners were looking for it. Hope they keep it stocked.
   / New Source, Oil for Kubota #8
I sure wish MINE would have had it on the shelf before I bought my 5W-40 SYN Rotella. Awe well???
   / New Source, Oil for Kubota #9
I'm running the 5W 40 SYN Rotella in my BX. I don't think you can find a better oil for it.
ron
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2014 JOHN DEERE 35G EXCAVATOR (A51242)
2014 JOHN DEERE...
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
2006 Kenworth T600 Semi (A50514)
2006 Kenworth T600...
1996 International Bucket Truck (A50323)
1996 International...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
