New RTV 1100 cab doors removable ?
   / New RTV 1100 cab doors removable ? #1
logfarmer
Bronze Member
Northport, NE Washington state
I am going to buy an RTV with a cab but want to be able to leave the doors off in the summer. Does anyone know if the doors on the new factory cab are removable?
Martin
   / New RTV 1100 cab doors removable ? #2
Yes you can remove the door on the rtv1100. I have not taken them off yet but is just like the curtis cab on the rtv900. The hinges are more heavier duty on the 1100.
   / New RTV 1100 cab doors removable ? #4
Why would you take the doors off, since you have factory air conditioning? just wondering
   / New RTV 1100 cab doors removable ? #5
I use the RTV to perform work on the farm I find it is much easier to get in and out of the machine. I ride the the Rows of Blueberries and I am getting in and out every few feet or sometimes I have a hand sprayer and will spray as I am driving along.
In NE Washington the summers are hot and dry so the air conditoning would be nice but not as nice as a breeze open doors and the abilty to get in and out easily. I like to jump on the 4 wheeler to run to one of our other houses to store or get something if the RTV isnt as easy to use as the 4 wheeler I probably would'nt want one.
In winter when plowing snow the doors and heater would be the way to go at that time. Spring and fall would be perfect.
Its really my wife who wants to get the cab id be happy with a windshield and a heater for the winter when we will run about a mile down the county gravel road to the mailbox and back probably at warp speed, 25 mph. The windshield would keep the bugs off in the summer and the cold or inclement weather in the winter.
Martin
   / New RTV 1100 cab doors removable ? #7
Martin
Sounds like you need a RTV900 and the wife needs a RTV1100.
Don't forget you have the Two-Position Door Lock System on the RTV1100 which will give you that nice breeze through the cab...
Not hot or cold enough for the heat or air conditioning? Let in some fresh air by utilizing the RTV1100's one-of-a-kind two-position lock. Located on the driver's side door, this ingenious lock allows the door to lock in a slightly open position, called ventilation mode, allowing the air flowing from the front to continue on through the cab and out the door. To complement this, the front windshield easily opens outward to allow air to flow through the bottom and sides. In airtight mode, the door is completely closed and the cab is sealed tightly for efficient air conditioning and heating use.
Fiser Truck & Tractor: Kubota RTV1100 Utility Vehicles
   / New RTV 1100 cab doors removable ? #8
Toy 1,
I use my RTV on the plantation also, you said that you use a spray unit.
Just a little something that might help you in your type of work. Or maybe
not. Anyway, last week I rigged up a "ropewick bar" for the RTV. Use it on
the front reciever. Built a hitch that fits into it, and the wickbar adjust up
and down as the level you need it . It works
perfect for knocking out the unwanted items in the rows . Don't know what
your spraying, but if it's any type of herbicide, it does work wonders.
Thought I would throw that at you..... :)
   / New RTV 1100 cab doors removable ? #9
Ropewick bar ? what is it and how does it work?
   / New RTV 1100 cab doors removable ? #10
A ropewick is a PVC pipe, with rope applicators . The roundup or any other chemical wished to be used, is filled up inside the wickbar, as the bar is adjusted 4-9 inches, ( or whatever you are comfortable with) above the crop that you wish to harvest. The "rope" applicator rubbs the unwanted plant, that has grown "above" the crop you wish to keep. The chemical is applied to the unwanted plant which will die off just as if you would have sprayed it. No chemical ever touches your crop that you are growing for profit !
It saves alot of time, MONEY, cuts all your expenses to almost nothing.
I going to try to attach some links of some wickbars, some of them may be looking big as they may be installed on big tractors, you can purchase the bars at any width that you want. But I made mine 8 foot wide for the RTV, and it works PERFECT !!!!!!!!!!!
Rodgers Sales Co., INC
ACR SALES - Ropewick, Speidel Applicator, Speidel Weed Wiper, Wicks, Wick Applicators, Herbicide Wicks, Weed Wipers
Bowman Manufacturing - Viewing Products: Ropewick
This is a good one :
Rope Wick and Weed Thief Applicator
Why Use a Wick Bar?
For maximum crop yield, a wick bar is a versatile, fuel-efficient, and easy-to-use tool for both broadcast, row-crop farming and also use in your pasture and orchard.
Correct application kills noxious vegetation growing above your crop. Kills most broadleaf weeds as well as Johnson grass, volunteer corn, shatter cane, pigweed, etc.
- Environmentally safe application eliminates costly down-time due to wind or spray drift.
- Simple to operate with no pumps or guages.
- Folding bars aid access to remote fields.
- Built Farm-Hand Tough to Last!
LET ME KNOW IF THIS HELPS OR NOT ~~~~~
THESE "BARS" SURE MAKE FARMING ALOT EASIER, AND KEEPS MORE MONEY IN YOUR POCKET WITHOUT THE PROBLEM OF THROWING YOUR MONEY THREW A SPRAY UNIT !!!!
Towable Message Board (A44571)
Towable Message...
Kubota RTV900 4x4 Utility Cart (A44572)
Kubota RTV900 4x4...
24ft x 28ft Metal Building (A44391)
24ft x 28ft Metal...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A42742)
2017 Bomag BW90...
2025 HD Trailer Solutions 20ft 7.5 Ton T/A Flatbed Trailer (A42742)
2025 HD Trailer...
Western Pro-Flo 900 Salt Spreader (A42021)
Western Pro-Flo...
