new pt
   / new pt #1
markpin
Solon, Ohio
none yet
Greeting to All,
First, I need to thank all of you for the valuable info on the PT's. I am considering buying a 422, and have been reading your posts for a few weeks now. I am somewhat torn between buying the pt for is obvious usefullnes and the dreaded problems some of you have experienced. I have a smaller lot (2 acres) with one acre of it being a pond. I believe it would be a great machine to have just to Mulch, build some retaining walls, plow the drive etc...I don't think it would get some of the "tougher" use that many of you put them through, so maybe , just maybe I wouldn't have some of the problems. In any case, before I pull the trigger, I will try to find one a little closer than Tazewell to look at. A six hour trip just see one in Tazewell just hasn't been the easiest to schedule lately. Are any of you somewhat close to the Cleveland, Ohio area where I might be able to take a peak close up at one of these unique machines. Thank you.
   / new pt #2
Remember we only post our problems (and our mods and projects0! I have never posted saying no problems in the last two months. And we save so much on the tractors that we can afford lots of repairs in comparison if we have to. If you do not mind repairs, the used ones are a particularly nice deal.
Ken
   / new pt
Ken,
Thank you for your reply...I am wondering if most PT users take the trip to Tazewell to see the machines for the first time, or have most of you seen them somewhere else first such as a show etc...
Thanks,
Mark
   / new pt #4
Welcome,
Maybe you have read some of the SwampmanLA post, that's me. I bought a 422 in February and found that the tram pump was faulty soon after. Well I was not going to drive the 800 miles to have them swap it out so I did it. Not easy but I learned a lot about my tractor. After that I just love the thing. I can't tell you how much time it has saved me, not to mention back pain. No way would I let it go. It is a great machine. As for the horror stories about Tazwell support, all I can say is they are great and very helpful. Terry has gone out of his way to help me. I doubt you will regret purchasing a 422.
SwampmanLA
   / new pt #5
I have 600 hours plus on my 2000 PT with Robin engine. I have had few problems and all have been minor and supported well by Power Trac. They have excellent phone support. You are welcome to come use my machine, but I am in VA. I bet someone else will though.
   / new pt #6
I have had my PT for about 5 years (2003 model), and have had very very few problems with it. I've worked it plenty hard. It had a leaky wheel motor when it arrived (I had to take the wheel off and tighten a connector). I have had to do routine maintenance, but other than that, it's been absolutely flawless. I would not be that concerned. I do use synthetic oil and change oil and filters regularly. I also make sure the cooling fan (I have a PT425) comes on when it gets hot. I would consider getting the PT425 over the 422, but that's up to you. I find the 425 with the cooler and the ROPS, not to mention more power, etc. is exceptional.
Rob :)
   / new pt #7
I bought mine used and sight unseen. After having driven a few different tractors around I knew what I was getting into... I was not prepared for how manueverable they are, nor how stable.
I finally got some PT puckering happening last time i was up north... maybe just llight in the loafers more than pucker... Maybe also the reason I am replacing my bearings and spacer ;-)
This site will help you judge wether it is right for you or not. All indications by what you have written seem indicate this as a good purchase for you.
Carl
   / new pt #8
I bought my PT without ever even having seen one. The decision was easy because of the information from this forum and knowing that its members could help with support.
Ken
   / new pt #9
I bought my PT425 at the end of March after owning a CAT 216 Skid Steer for 5 years. Other than the 6 -12 times I need to lift something over 1000 lbs or spin around while in place, this machine could run circles around the CAT. The versatility is great.
I made my decision to purchase based mostly on what I learned here and from the features I liked about the skid steer, primarily being able to be up close to the work area. I did test the machine locally before I went to Tazewell , but this forum did more to convince me. I also would recommend the 425 vs 422 based on beefed up parts(wheel motors, 2 cylinders for articulating, etc.). Many years of experience has taught me that you are always better over-buying when you purchase equipment. There is less chance of wear or damage because at some point, we all push equipment more than we should and the machine with the extra "beef" will hold up better.
I only have 20 hours on my machine(doing my first oil change today), but it has exceeded my expectations. Good Luck on your decision.
   / new pt #10
Welcome to TBN! :)
I had the oppotunity to see one working and sit on it before I purchased. I really suggest you do the same. Also, do not discount other tractors. Do youself a favor by taking a long time to make your decision. Test drive as many makes, models, brands, styles as physically possible to make yourself an expert in what feel right under your seat. :)
I run our PT425 on 1 acre. It is crazy how fast you can get jobs done compared to a lawn tractor. Mowing, landscaping, hauling stuff around, plowing snow, etc... is so easy.
We also use it on our 20 acres outside of town to maintain the trails and haul wood out of the forest. Someday, when we build there, it will also do the lawn and driveway.
We've had it for about 7 years and are very happy with it.
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
1999 KENWORTH T800 DAY CAB (A53426)
1999 KENWORTH T800...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53473)
2018 Link-Belt LBX...
