New post
   / New post #1
taem
Derby Vermont
Jd2240,Case IH 75C,Jd2750
I'm a part time farmer in northern VT with 35+ beef cows and about 25 acres of hay. Sell some hay and keep most for my animals. All equipment is used, some pretty nearly antique, but I am gradually moving up. got a used rotary rake for the first time this year, after years of good service from a JD 640. Sorry to see it go, but the rotary is soo much better and easier to use. Ditto a "new" discbine a New Idea 5209 white,not red replacing my almost thirty year old Hesston 1050. I'm still learning that one. Right now, I am looking for a replacement tedder--I have a Fanex 500 that I have spent hours rebuilding, and although I have corrected every fault I can find (bent wheel struts, a twisted shaft, a couple of broken gear teeth and more) it just doesn't do the job I want in heavy hay--leaves a lot on the ground, and doesn't fluff well enough. A really good mechanical friend has tinkered too, and his advice is to cut my losses. What would be a good replacement used? and how to avoid trouble if I buy another of these (there are a lot of the Vicon RS510's around here which is the same machine) Thanks
   / New post #2
welcome to TBN:thumbsup:
.... sorry, hay is not my thing...surely somebody will be able to comment on your question
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
44510 (A51692)
44510 (A51692)
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
