New pallet forks
/ New pallet forks #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
Finally purchased a set and cant wait to use them. 48" long 4000lb capacity and weigh about 450lbs. Little heavier than i initially wanted but Ill abuse them a little and use the loader to its full potential. Pics tomorrow.
/ New pallet forks #2
Good luck with the new forks. I view em as money in the bank: you will never know when you might need em. I moved this ornamental bridge for my neighbor with my Payne Forks from Northern Tool. They are detachable, but they got the job done that day.
/ New pallet forks #5
I have a landpride set, 48'' 3,000# capacity weighing in a little less than 400lbs. Also heavier than what I woulda have liked. I just don't see where the weight is, must be in the forks themselves.
/ New pallet forks
They are going to let me use them for a little bit and i can return them if i find them to much but this model is all they sell. Because all the others people were bending and they were tired if the complaints about other models.
/ New pallet forks #7
I have a set of Wildcat 48" Quick Attach forks I've used a good bit. Just moved a pile of brush by scooping it up with the forks and moved it to my big burn pile. Also lifted an old washer to put in the back of my pickup to carry off. Tried to pick up a pallet of Quickcrete cement - a bit too heavy. I had to remove a few bags first. Found out my boxblade is just a bit light to counter the capacity of my loader. Forks are worth it!
/ New pallet forks
Mine is the 4048. Ill get some action shots this later this week
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
2019 GREAT DANE CS1-1314-21053 53X102 DRY VAN TRAILER (A59912)
2019 GREAT DANE...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2006 Hitch and Trailers Inc. 12ft S/A Utility Trailer (A61574)
2006 Hitch and...
1762 (A58375)
1762 (A58375)
