new owner satoh buck s470d
   / new owner satoh buck s470d #1
stockinglover33
I have a satoh buck s470d tractor four wheel drive where can i find ag tires for the rear there 9.5 x18 have tried all local dealers none have ever heard of 18 inch tractor tires
   / new owner satoh buck s470d #2
Tractor supply has em, also firestone should be able to get them. May be try these guys, /www.nebraskatire.com/
Good Luck
   / new owner satoh buck s470d #3
I have a Mitsu that also uses 9.5 X 18., mine are R3's
Made by Bridgstone, and yes hard to find= no deals out there but can be had.
With 4WD you need to match fronts correctly otherwise you will trash your front differential, so be careful.
If you are changing from something to ags you might even need to change rims!
Due to age mine are weather checking and must be done fairly soon.
I did locate some @ $325 Cdn ea and decided to wait a bit longer.
Good Luck
after searching and trying for several hours we have decided to go with a 10.5 backhoe tire want have to change the size of the front tires since we will be running the same type tire on the front made by firestone and there only 229.00 each way cheaper than other tires and no shipping needed
2012 Freightliner Cascadia (A61306)
2012 Freightliner...
2019 TAKEUCHI TL10V2 SKID STEER (A60429)
2019 TAKEUCHI...
SKID STEER QUICK ATTACH PALLET FORKS W/ 48" FORKS (A60432)
SKID STEER QUICK...
skeleton / rock bucket (A56857)
skeleton / rock...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
2024 Chevrolet Tahoe SUV (A59231)
2024 Chevrolet...
