New owner questions
   / New owner questions #1
Mitsnewbie
Mitsubishi mt2201d
Recently purchased a mt2201d & have some questions. Is there anywhere that has repair manuals for these? It came with an owners manual. I've never had one with a dual stage clutch before, it seems like the clutch engages real high on the pedal throw.
Is that normal with this type of clutch? If not normal, is there any way to adjust it? The owners book shows a freeplay adjustment but I'm not sure if that's what I need. Any help is appreciated 👍
It came with a loader, back blade, mower & a rake.
   / New owner questions #2
If it does not have a hydrostatic transmission, yes that is normal as you do not feather the clutch like you do in a vehicle. It is either all the way in or all the way out.
Takes a little to get used to.
The previous owner gave me a manual for the tractor but it turned out to be for a mt280 instead of a mt2201d. Most things seem the same but I don't think the 22 has a dual stage clutch. I was able to adjust the freeplay & it seems ok now. Changed oil & filter, went to change fuel filter but the po had installed an inline filter so I didn't have the right one . Need to figure out how to adjust the throttle stop on the low idle end, you can shut off tractor using the throttle now.
2022 JCB 3TS-8T Teleskid Loader with Telescopic Boom, DB84 Dirt Bucket and FAE Forestry Mulcher (A55218)
2022 JCB 3TS-8T...
2020 Deere 325G (A50123)
2020 Deere 325G...
2012 International 4300 Reefer Truck (A55301)
2012 International...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
