Oil & Fuel New Owner, Old Tractor-1974 Ford 2000 Gas -Trans., Rear end fluids?
   / New Owner, Old Tractor-1974 Ford 2000 Gas -Trans., Rear end fluids? #1
BluTomm
Trimble, MO, and NW Arkansas
1974 Ford 2000 Gas, Bolens 1220 and G-14 Garden Tractors
Hi all. I'm new to this forum, and new owner of an old tractor, a 1974 gas Ford 2000 with 6 speed trans. I'm trying to figure out what type of fluid to put in rear end and transmission. I have bought an owners manual and service manual(IT), and have a Ford service manual on the way. The books I have call out all different numbers, most of which I haven't been able to cross. I think regular 85-90w gear oil should work in the manual transmission, but not sure about the rearend, since it is also the hydraulic fluid. One tractor hyd/trans fluid I looked at was only 10-20 weight oil..? I want to use the correct fluids, but don't like to use real thin oil, unless that is what's required for the hydraulics. I just want to check and top off fluids for now, because I have some brush hogging to do, then plan on changing all fluids over the winter. Any help will be appreciated.
Thanks, but that tractor has 3 seperate areas for fluids- transmission, rearend, and hydraulics, from the sound of the answers he got. I believe mine only has 2, the trans, and the rearend and hydraulics are together in the rearend.
   / New Owner, Old Tractor-1974 Ford 2000 Gas -Trans., Rear end fluids? #4
In the transmission you can use 80w90 or UTF. In the rear diff/hydraulics you should use UTF.
Thank You, Chris
Tom
   / New Owner, Old Tractor-1974 Ford 2000 Gas -Trans., Rear end fluids? #6
You are welcome Tom. Good luck with your tractor.
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
SET OF 51" HANG ON WHEEL LOADER FORKS (A51246)
SET OF 51" HANG ON...
2020 JOHN DEERE 7R210 LOT NUMBER 47 (A53084)
2020 JOHN DEERE...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
