New owner of a '94 GT6000, 18hp Kohler Magnum Hydrostatic, 44"
   / New owner of a '94 GT6000, 18hp Kohler Magnum Hydrostatic, 44" #1
skm348
TN
none yet
Just picked it up Wed. Changed the oil & filter, plugs, and greased it up. I have a couple of questions though..
I noticed back on the side-part of the hydro tranny housing there is what looks to be a spin-on type oil filter which I assume is for the tranny. I'd like to replace it if I can bit am wondering would fluid spill out & if so how would I put in back in? I believe these are sealed units which means there's no way to add fluid.
Also, tried taking off the air filter housing by removing the wing nut on the top but I can't get it off. The metal top spins around easily enough but it won't come off. I don't want to force it as there may something else holding it down. Any ideas?
Finally, the starter sometimes spins a bit before starting so I'd like to clean it up and maybe lube it around the part the goes up & down that engages the flywheel gear (or whatever it's called). Do I simply remove the bolts around the engine shroud and starter and lift it out? I'm not overly mechanical like most of you guys but I do want to try it myself and learn how to do things.
The engine is strong, tranny seems fine & it cuts great so I'm glad I bought. Got a very fair deal from the orig owner. Tires are good as well w/no leaks!
Looking forward to learning more and more from this great forum.
Thanks!
New Holland 325 Manure Spreader (A55218)
New Holland 325...
LEEBOY PF1510B ASPHALT PAVER (A51406)
LEEBOY PF1510B...
1999-2010 Ford Pickup Truck Bed (A52377)
1999-2010 Ford...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 TRUCK (A51406)
2011 INTERNATIONAL...
