New owner of a 2006 TC30-any advice?
   / New owner of a 2006 TC30-any advice? #1
ksshooter
Bronze Member
NE Kansas
New Holland TC30
I picked up my used 2006 TC30 HST w/Rhino 2408 loader :D(less than 350 hrs) on Tuesday. Prior to this I have owned a 1962 Ford 2000 with a HUGE loader and a 1959 Ford 641 Workmaster which I a about to sell. I mostly mow and do road and pasture maintenance. I acquired horses last year and I needed 4wd for the winter work and a loader for lots of reasons :cool:(need to get a spear). The previous owner stated he had completed all of the 300 hour required maintenance which included coolant, crankcase oil, rear axle and trans fluid, front axle lube, differential lube, hyraulic filter, HST filter, fuel filter and engine oil filter. This is my first diesel!! Just wanted to know if one of you experience small diesel owners had just purchased this what you would do and do you have any words of advice. I am in Northeash Kansas and it does get cold. So far I researched what diesel additive is recommended and what oil(s) are highly thought of on TBN. I will use a synthetic for sure. Thanks in advance and I truly appreciate this website and I will try to use it's sponsors whenever possible.:thumbsup:
   / New owner of a 2006 TC30-any advice? #2
I can't offer much advice, but if you do get and use a block heater, run the extension cord through the steering wheel so you don't accidentally drive off with it connected and pull apart the heater wire.
Wow..that is good advice. I have done something very similar with my lifted electric golf cart that I use a great deal but uses a separate battery for the lights.:ashamed: Plus yesterday I read the one about carrying your chain saw in the bucket and forgetting about it being in there. Although I have done it, the member who asked his children where is chain saw was and got "you buried it Daddy" was priceless!!! Luckily mine have not been around during most of my "Oh S%&T!!" moments. Thanks again for the tip!! By the way, where did you get your heater? From New Holland $$$ or ???
   / New owner of a 2006 TC30-any advice? #4
Run a diesel antifreeze or if using regular antifreeze add Fw-15 New Holland conditioner even though your have a dry liner block.
   / New owner of a 2006 TC30-any advice? #5
I have a TC40A which I bought new in 2007. I live in western NC in the appalachian mountians where the winter temps range from teens to thirties at night and twenties to thirties during the winter days. I use Rotella 15/40 engine oil with no problems for 350+ hours. For a fuel additive I use the SP brand from Walmart which has slick 50 diesel supplement. This is the same combo that I have used in my Ford 1210 since purchased new in 1984. The pre heat glow plugs on both tractors have always produced a cold start no matter what the temp was. My TC40A does have an annoying pump whine in cold weather until it warms up. I move a lot of snow with mine with chains front and rear. The vibration from the front chains have caused my radiator to seperate twice now and NH would not warrenty it. My starter solinoid is now going out premature with less than 400hrs. Other than those two problems the tractor has performed as expected.
Good information! We do not normally get large snowfalls (last year was an exception!) however we do get COLD! Minus 27 was the coldest morning last year that I remember but 5 to 10 below is not that abnormal. The tractor will be lept inside (just as soon as I fix my ROPS problem, but that is another high energy subject) all winter. The workshed is not heated but it does make a huge difference keeping equipment out of wind and snow. I have never had an engine heater for a tractor, but I understand diesels can be a bit more difficult. Is your TC40A an HST? This is my first Hydrostatic tractor. My riding mower is hydrostatic but I don't mow in the winter :) Thanks again!
This is for Sweep....I need to ask the previous owner if he used diesel anti-freeze but I can almost guarantee he did not. What is a "dry liner block"?
   / New owner of a 2006 TC30-any advice? #8
It means that if the cylinder has a liner, it's never touched by coolant. It's a liner within the bore casting.
   / New owner of a 2006 TC30-any advice? #9
Sell it!!!
No, seriously...do some research about the TC-30 loaders breaking the tractor. This isn't to alarm you, but to make you aware of one of the potential issues with your tractor and how you use it.
   / New owner of a 2006 TC30-any advice? #10
As Roy mentioned, the TC30 has no sub-frame mount for the loader. I'm not sure about your Rhino loader, but the New Holland 7308 loader doesn't use a sub-frame. That just means you will have to be careful not to slam the loader into things or lift with one side so the tractor is twisted. I also do not recommend trying to handle round bales with your loader. I'd use a 3PH bale spear on the rear instead of trying to lift with the loader. You may get the bale into the air, but if you hit a pot hole or rock while traveling, the dynamic loads will really put a heavy shock on the tractor and loader. The ideal situation is to have a tractor with a sub-frame and a skid steer quick attach adapter. No sub-frame and a bucket spear is just really asking for trouble on a TC30 in my opinion. You might get away with it for years, but one time is all it takes to be a very costly mistake. Big tractors or CUTs with sub-frames are needed for the safest round bale handling with the FEL.
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A51692)
2015 Ram 5500...
2011 Deere 650J (Camilla, GA) (A50123)
2011 Deere 650J...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2008 Ford F-250 Service Truck with Liftgate (A51692)
2008 Ford F-250...
2001 MACK CH613 KILL TRUCK BOBTAIL (A53843)
2001 MACK CH613...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
