New (Old) Cushman Trackster -- Craigslist is Evil
   / New (Old) Cushman Trackster -- Craigslist is Evil #1
Wombat125
SE Wyoming
John Deere 5303
So I accidentally bought a mid 70's Cushman Trackster. I say accidentally because I was looking for pallet forks and snowblowers and such.
The fiberglass is a little rough, but it seems ok mechanically. It runs good and smokes like a 2-stroke banshee. The tracks are so-so.
Any idea what she's worth?
BODY: Heavy fiberglass wit gel-coat finish (color molded in).
ENGINE: OMC 25 or 29 HP die-cast aluminum, air-cooled, two-cycle, electric start.
DRIVE: 2 Sundstrand hydrostatic transmissions, drive shaft driven with gear reduction on output.
CAPACITY: 800 Pounds.
SUSPENSION: Each set of bogie wheels is individually suspended by rubber torsilastic mount, steel springs, and rubber shear mounts.
CONTROL: T-bar lever control for steering, reverse, power and braking. Variable throttle for speed and power control.
ELECTRICAL: 12-volt solid state ignition system, key-operated electric start, headlight and charging system for battery.
TRACKS: One-piece rubber with steel cord construction. Double drive lugs molded on inside.
DRIVE SPROCKETS: Rugged steel casting.
BOGIE WHEELS: Die-cast aluminum with water tight triple-lip seals and shield for protection of ball bearings.
FRAME: Welded steel tubing.
AXLE: Steel with heat-treated-center aluminum housing.
GRADEABILITY: 100% grade or 45ー plus.
SPEED: 16 MPH forward, 7 MPH reverse.
TOW HITCH: Rear; tow ring in front.
WEIGHT: 985 pounds.
GROUND PRESSURE:
Dry unloaded.........................0.47 PSI
Wet with 1 operator...............0.60 PSI
Wet with 2 persons & 100# equipment..............0.73 PSI
HEIGHT: 41" LENGTH: 92" WIDTH: 61"
   / New (Old) Cushman Trackster -- Craigslist is Evil #2
I guess what it's worth is up to you eand the end user but that thing is pretty cool! I'd modify that drive sproket to a ASV style drive. then you could fly whithout chewing up the belt. Does it have suspension?
   / New (Old) Cushman Trackster -- Craigslist is Evil #3
Years ago, I've owned two of them, run the heck out of them, really never had any trouble at all........
Back then, that was the " MACHINE "
Looks like it's in good shape for it's age.....
Keep it and enjoy !!!!!
   / New (Old) Cushman Trackster -- Craigslist is Evil #4
I agree on the Craigslist is evil thought. I was was looking for a stick welder and ended up buying a Ranger pickup.
Great little machine you found, glad I didn't see it first.:D
   / New (Old) Cushman Trackster -- Craigslist is Evil #6
Ive been searching for a trackster everywhere! If you still have it and you want to sell it please let me know!
   / New (Old) Cushman Trackster -- Craigslist is Evil #7
Ebay has one today 12- 11- 2009
item # 160386336864
or the second Cushman
Item # 180444367046
Take a Look
........ two guns
   / New (Old) Cushman Trackster -- Craigslist is Evil #9
Never saw a Cushman Trackster before but saw an ad last week for one. Looked brand new, very few hours, more like a meseum piece . Asking 4500 or best offer. It is located in Wi.
   / New (Old) Cushman Trackster -- Craigslist is Evil #10
I am new here so bare with me. I just wanted to say I use to Have three Tracksters years ago. They would go anywhere. And could turn on a dime. I used them down in the cedar swamps in South Jersey. The reason for this post is I know quite a lot about them. When I first started trying to get my first one going I could not find any info anywhere or parts. It was one dead end after another. I lucked out and made a contact which led to another and so on. The people in the trackster community were grate and helped me alot. So if any one needs any information I am more than happy to help if I can. Good luck and take care.
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
Killbros 385 Gravity Wagon (NICE) (A50774)
Killbros 385...
Dingo TX427 Mini Skidloader (PARTS) (A50774)
Dingo TX427 Mini...
2016 Ford F-550 4x4 Ext. Cab and Chassis Truck (A50323)
2016 Ford F-550...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
John Deere 648H Grapple Log Skidder (A50322)
John Deere 648H...
