New NH TC40 vs. used NH 2120
   / New NH TC40 vs. used NH 2120 #1
Bulldogger
Bronze Member
Georgia
Kubota M9540, FORD 1920, Bobcat S300
I have been looking at new tractors and just can't decide to buy a TC33D, TC35 or TC40. In my looking I have found a used 2000 NH 2120 4wd with 12x12 shuddle shift trans and 1 remote on the rear with a canopy and 128 hours for 12,900. Is this a good price? Also does anyone know of any problems with the 2120's. Should I buy a new TC40 or the used 2120? I have a couple of pictures of the 2120. Thanks for your help
Another picture of the 2120.
   / New NH TC40 vs. used NH 2120 #3
There was a thread within the past 6 months about the 2120 and the various issues related to it. Do a search on "2120" and you should get some good hits. The price you gave is hard to guage without knowing the hours.
2120 pluses: total Shibaura product, been around along time, clutchless shuttle(?), all metal construction, that canopy looks nice. Negatives: no folding ROPS, older design/user interface, no loader (on this one if it is important to you), no warranty (looks like it is from a dealer - maybe you can negotiate a warranty), high exhaust stack (noiser/in your face).
I have seen another TBN user claim that mechanically the TC40 is the same as the 2120 - don't know that for sure. Pluses available folding ROPS, available deluxe 3ph, warranty, more tire choices(?), 0% interest financing, more refined user area, under chassis exhaust. Negatives cost of new, parts come from all over but are assembled in US (also a positive).
I can't speak to how this will meet your needs since you state none, but I bought used (with balance of a warranty) and I am happy. If I didn't find a warrantied used tractor, I would have bought new.
Good luck!
Mark
Mark I forgot to include the hours in my post it has 128 on it. I am pretty sure that you have to use the clutch to shift from forward to reverse.
I know its hard to beat 0% and the prices that I have found on most of the used stuff is not that much cheaper than buying new. I would just like to get some input from other tractor people. Thanks for the info.
   / New NH TC40 vs. used NH 2120 #5
128 hour is nothing! The lowest price I was quoted on a TC40 was in the mid $15K's. If you can get a warranty, it sounds like the 2120 might be a good deal. There may be, in fact, the remainder of a the powertrain warranty left. NH gives 2yr bumper-to-bumper and 3yr powertrain on the TC's. Don't know about the 2120....
If the dealer is not NH, get the s/n and call a NH dealer to see how much is left. I found a 500-hour TC45D with a Bradco backhoe used from a JD dealer. He gave me the s/n and I called a NH dealer. It had 1 month/13months left. I also found out the backhoe had cracked the tractor in two. I didn't buy that one....
As was stated on the Faber College founder's statue in the movie "Animal House": Knowlege is Good!
Mark
   / New NH TC40 vs. used NH 2120 #6
Bull dog-The 2120 is a good tractor,no loader kind of stinks,they are expense-that is very low hours>? keep us posted
   / New NH TC40 vs. used NH 2120 #7
The 2120 is an excellent tractor. It's been out since about 1987 and I've had one since 1988. Very reliable. The frame on a 2120 is considerably larger and stronger than a TC40, or 45. With the shuttle trans you can shift from forward to reverse without the clutch. The price you quote for the number of hours seems very good. A typical price for one with a loader and a lot more hours is 16- 18k. There have been some posts on this site regardiing loose bolts, and leaks on 2120's . I've had none of these and I've used my hard. Ny dealer leases and sells many 2120's each year and I asked him about those type problems and he tells me that he just doesn't see many problems with the 2120. Given a choice I'd take a 2120 anyday over any Boomer. It's just a bigger, more capable tractor. I pull mostly 8' implements, heavy york rakes, box scrapers, etc and a 6' brush hog.
Andy
   / New NH TC40 vs. used NH 2120 #8
That seems like a good price for a relatively new 2120 tractor in good condition with low hours. Make sure it's not an older Ford version that someone has redecaled and painted the grills black however. The manufacturers tag on the underside below the transmission should tell all. NH/Fords shuttle-shift worked extremely well and was very easy to use. Yes you had to clutch, but it was very simple and effort-free. If your looking for true convenience of operation however, you can't beat a new Boomer. Especially the 35D, 40D, 45D series with the electronic shift-on-the-go range changing switch for the hydro. The other creature comforts such as the adjustable steering column, etc also make it more effort free to operate. I think the 2120 excels for straight ahead work while the Boomers with a hydro trans have a heads up if your doing a lot of back and forth work such as using a loader or mowing around obstructions or plowing snow. Either way, I think you'll be happy with either choice.
   / New NH TC40 vs. used NH 2120 #9
</font><font color="blue" class="small">( I have seen another TBN user claim that mechanically the TC40 is the same as the 2120 - don't know that for sure.)</font>
The 2120 is closer to the TC45 IMO. The 2120 is physically a bit larger thean the TC40/45, and the 2120 is about 500# heavier. Engine on the TC45 is 135 cu. in displacement, 45 HP @ 2600 RPM. Engine on the 2120 is 138.5 cu. in, 42.6 HP @ 2500 RPM (basically the TC45's engine is the same as the 2120, just cranked up a bit).
I think the 2120 is a great tractor & the shuttle shift is a great transmission. The price seems decent for a tractor with the low hours you mentioned. I'd give it some serious consideration.
John Mc
   / New NH TC40 vs. used NH 2120 #10
I have a brother in law selling his 2120, a 1996 model with about 500 hours and a loader. He asked me about a price for it. I figured about $15,000 with a 2 remote setup on back and a NH post hole digger. Exhaust is turned down on his. Rat...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2021 John Deere C12R Corn Head (A53342)
2021 John Deere...
Yale GLC050LXNVAE087 5,000lbs Propane Cushion Tire Forklift (A51691)
Yale...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
NEW Fork Extensions (A53002)
NEW Fork...
