New motor tines going backward?
   / New motor tines going backward? #1
stangman548
little rock, ar
troy-bilt
OK, im new to the forum and tillers in general. Me and my father installed a new (knockoff) engine. It runs great and the tires go foward, but the tines are turning in the foward direction which is backward right? Is there something I done wrong or what? I just dont see why the tires are going foward but the tines aren't. Please help me.
   / New motor tines going backward? #2
Stangman Welcome to the Forums. and TBN
And It would help if knowing the type and brand of the Roto Tiller.
I recently exchanged the engine to a rear tine Montgomery Wards tiller and the orginal engine a Briggs had the second shaft that ran the wheels. I installed a Honda with out the 2nd shaft and added a pully to cross the belt to drive wheels the correct direction it works.
There is a large number of members from Ark.Guess all busy getting the garden taking care of.
ken
O im sorry, It is a troy-bilt. From the pictures im guessing it's "the horse." It has the foward and reverse selector and high and low for the wheels. It only has the one pulley on the engine and the one on the trans.
   / New motor tines going backward? #4
Mine runs tines same as wheels, like this one.
[ame]http://www.youtube.com/watch?v=ib3rtZ7I9Xw[/ame]
This one runs reverse. Is yours like this:
[ame=http://www.youtube.com/watch?v=roo9bvY3txs&feature=related]Troy-Bilt® How We're Built: Cast-Iron Bronze Gear Drive Transmission - YouTube[/ame]
Bruce
The tines are running same as the wheels. When I put them on the ground, the machine took off. I thought they were supposed to run backwards of the wheels to dig down?
   / New motor tines going backward? #6
Are you tilling in low and not in rock-hard ground? Notice in the top video (0.15) after he raises the depth limiter, he hits a rock or hard spot and the tiller jumps ahead. The depth limiter should be set for shallower tilling if it is jumping ahead.
Bruce
Thank you for all of the information, I guess I was just being to aggressive with it. I am going to give it a try tonight and see what happens. Thanks again guys the information was very helpful.
   / New motor tines going backward? #8
Troy Bilt Bronco 6HP CRT Rear Tine 14" Tiller 21C-64M-1066
This model here the tines run in reverse of the wheels. C Counter R rotating T tines. Sounds like you are good to go.
Yepp tilled a little bit with it the other day and got it figured out. Works awesome
   / New motor tines going backward? #10
The tines are supposed to turn forward. I am sure of it. I left mine in neutral one time and engaged the tines and it took me for a ride. Do not want to do that again. :laughing::laughing::laughing: Felt like a rag in the wind.
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2010 Ford Flex SUV (A48082)
2010 Ford Flex SUV...
Fuel Tank (A50860)
Fuel Tank (A50860)
2016 Ford F450 (A49461)
2016 Ford F450...
2010 Acura TL3.5 Sedan (A48082)
2010 Acura TL3.5...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
