New MF1220 owner...a few questions
   / New MF1220 owner...a few questions #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Hi Folks:
I just got my hands on a 1993 MF1220 HST w/1242 FEL. It's got 305 hours on it...should be barely broken-in for a mini-diesel, eh? The hauler dropped it off today, and my daughter and I drove it around the neighborhood /forums/images/graemlins/cool.gif.
Everything seems to be in pretty good shape. There's a little surface rust in a few spots and the paint is a little faded...I'm not too concerned about either of those, although this would indicate to me that it's spent much of it's life sitting outside rather than in a shed. Two things that do need fixing, however.
1) The fuel guage doesn't seem to work. Anyone know what's the most likely piece that has failed here? I'd assume there's some fuel level sensor that plugs into the tank and some wires that go to the gauge. Is the most likely culprit the guage itself, the sensor, or the wiring in between? If anyone has any insight, I'd appreciate it. I'd imagine the parts aren't very expensive (although I could be wrong!)
2) The 3pt hitch and loader hydraulics stumble on the way up. I've seen the other post about this, and I'm hoping the hydraulic filter is partially clogged and the stumble is from the filter's relief valve opening and closing. I'll likely take it to the dealer about 30 miles away within the next couple weeks and get them to replace all the fluids and filters and look for any issues, etc. I eventually would like to do all this myself, but paying the dealer to do it the first time might not be a bad idea. Do you agree?
Those two things out of the way, it starts right up, runs very smooth, is considerably quieter than the Power-trac I used to have, all the lights work, I don't see any evidence on the ROPS of it ever having been flipped, and it sure feels like it would pull a mountain without stumbling. It's shorter than the Power-trac I used to have, but taller and quite a bit heavier (about 2100 lbs w/ the FEL, according to the manual). I had to dig something today, so I moved a small pile of dirt left from where I dug a ditch with the PT last year (the guy who mows the neighborhood's common property always complained about the 5 seconds it takes him to adjust his mower height at that spot /forums/images/graemlins/tongue.gif) It seems to dig quite well...I guess 2000 lbs is indeed a "magic number" (the PT only weighed about 1200 lbs or so, so pushing into a pile resulted in wheel-spin unless you wiggled it side-to-side using the articulated steering).
Anyway, I'm really looking forward to getting to know this machine really well...both mechanically and operationally. I knew my old PT inside and out (not a traditional CUT), so this guy is a little bit of a different beast. Should be a fun journey! /forums/images/graemlins/grin.gif
Regards,
Dave
   / New MF1220 owner...a few questions #2
Dave, Congrats on the tractor purchase, On the fuel gauge check the ground on the lead to the tank. If you have a volt ohm meter you can pull the float sensor and see if it is functional with the ohm meter by moving the float up and down to see if you get increasing & decreasing resistance as you move it. If it is good, look at the wiring if wiring is good its probably the gauge.
On the hydro stumble, Before I would go to the dealer, Just for your own peace of mind I would change fluid and filter myself ,and if that didn't do it , I would consult the dealer for advice before I hand it over to them for a what could be an exspensive repair /forums/images/graemlins/confused.gif
Could be as simple as a fluid and filter change /forums/images/graemlins/cool.gif
   / New MF1220 owner...a few questions #3
I have a 1240, next size up in that series, and really like it. You're right about a quiet engine, I think these tractors are a lot quieter than other brands. I also agree that a filter change and fluid check might be the best first thing to do. A service manual would sure be helpful. You'll have a lot of fun with that tractor.
OK, might as well dig into doing the fluid changes myself. Just called the local dealer and they said it would run about $300 to change the fluids and filters (one filter is apparently $80...ouch!) I'm looking for the filter part numbers, but they don't seem to be in the operator instruction book. Does the service manual have these part numbers? I recall seeing a thread about mail-order manuals...I'll look for that and order the service manual.
My father-in-law worked for auto parts stores most of his life, and he says if I can get the MF part#, he should be able to identify WIX filters that are the equivalents and less than half the cost of the MF-branded filters (which are probably OEM'd from WIX or one of the other major filter mfgs anyway).
I checked the hydro fluid this morning...looks like it's right between the low and high mark. The hydro drive didn't stumble at all...just raising the loader or 3PH. I emailed the previous owner, and he says that's normal and it doesn't do it with any weight on either. Not sure I believe that...we'll see.
The fuel is magically working this morning. The previous owner said tap it a few times because it gets stuck (although it started working without any tapping). OK. I'd rather actually fix whatever the problem is, even if that means replacing the fuel guage. I'll check the wiring first as you kind folks suggested.
Thx,
Dave
   / New MF1220 owner...a few questions #5
Dave,
I would check all of your lines. You may have a leak that is letting air into the system.
   / New MF1220 owner...a few questions #6
Dave,
Go to your local NAPA dealer, they will have all the filters you need, for a whole lot less money. For all the filters on the tractor, and all the fluids, is going to be under $100. Get yourself a operators manual online to get yourself started on a maintainance schedule. Nothing difficult about that end of it.
scotty
Hey Scott:
Do I need the MF part #'s for the filters, or will NAPA be able to look it up by the tractor model?
I have the operator's manual, which lists all the maintenance tasks and how to do them. I don't have the service manual, which I'd assume lists part #'s for everything...correct or no?
Thx,
Dave
   / New MF1220 owner...a few questions #8
Dave- my local napa dealer was able to look up all of my filters with just the year/model. I listed the cross numbers for my 1240 hydraulic filter, but I don't know if it is the same for the 1220. You could check the MF filter that is on your machine and see if its the same number below.
NAPA #7110
MF #3703386 M1
WIX #557110
Awesome...thank you so much! It looks like from the operator's manual that you have to drain the hydro fluid to change the filters...is that correct? (On my old Power-trac, you just changed the filter and bled the tram pump...didn't have to drain the fluid, which is good since it was 10 gallons of 10W40 motor oil!) The manual mentions saving it to refill...seems to me if you're going to drain it, you might as well refill it with fresh fluid, unless it's ridiculously expensive!
Dave
Hey Jerry:
Will do. Do I run any risk of burning up a pump or other damage if there's air getting in? (In other words, is this a "don't run it until you fix it" type situation?) Any suggestions on where to start looking? (On my old Power-trac, the pump suction line was the only place to be concerned about, anything else would push the air out automatically.)
Thanks for the answers...I hope to learn the workings of this machine as well as I knew the Power-trac, but it'll take a while. I appreciate everyone's answers and posts!
Thx!
Dave
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
UNUSED Black Metal Roof Panels (A50860)
UNUSED Black Metal...
2013 Kia Optima SXL Sedan (A48082)
2013 Kia Optima...
2018 Chevrolet Tahoe SUV (A48082)
2018 Chevrolet...
2010 Ford F-250 Ext. Cab Pickup Truck (A48081)
2010 Ford F-250...
2018 JLG 1644 4x4 Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
