New Member
   / New Member #1
KenZ
Kioti 7320
Just purchased a new Kioti 7320 power shuttle with cab. Found this forum online and look forward to sharing information.
1 hour on tractor. If anyone has any good "break in" suggestions, please let me know. I asked the dealer and he didn't know anything. I know on new cars you should vary the speed and such for certain number of miles.
   / New Member #2
Welcome to TBN! Yes, you will find a bunch of info and help here! Go use the tractor...you will break it sooner or later.. oh, you mean a break in period...:D
When operating, you will automatically do different things / rpms, etc... there is not usually a certain procedure to follow. If there are any particular things, they would be described in the owner’s manual. Congratulations on the new tractor!
   / New Member #3
G'day Mate and welcome to TBN from Downunder.
Unknown how much experience you have with tractors but, the first thing that I would do is check all of the 'delivered' fluid levels and grease every nipple (zerk) that you can. Next would be to torque all of the wheel nuts (just to confirm) and then tighten every nut/bolt that you find. Lastly, if it moves, but doesn't have a grease nipple, spray it with a lanolin-based lubricant.
Enjoy the site... from wherever in the world you are.
   / New Member #4
Welcome and congrats on your Kioti!
:tractor: :wave:
   / New Member #5
Congrats on the new tractor and welcome to TBN. Other than checking fluids, torques, and making sure pivot points are greased vary RPM occasionally, which (as stated) will occur with various tasks anyway.
   / New Member #6
:welcome: to TBN...enjoy.
   / New Member
When operating, you will automatically do different things / rpms, etc... there is not usually a certain procedure to follow. If there are any particular things, they would be described in the owner痴 manual. Congratulations on the new tractor!
I've already broken 3 tractors! LOL That's why I had to get a new one! thanks for the comment. My concern is that I have a bit of hay cutting and brush cutting where the engine speed will most likely be constant for some time-hours. I know on cars/trucks, this is not good for breaking the engine in. I'll probably follow the guidelines for most diesel engines and try to work it at some various RPM's for a while. Thanks for your comments. The tractor arrives in a couple of days and I have not seen the manual.
   / New Member
All good things to be reminded of! and I do have some Berkebile PFC lanolin based spray that I use on a lot of things... great stuff! I'm in central Virginia, USA
Feteral 10"x60' Transport Auger (A50774)
Feteral 10"x60'...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
2006 Mastercraft S-05-1142 (A50120)
2006 Mastercraft...
Backhoe Bucket (A50515)
Backhoe Bucket...
Electric Mobility Scooter (A51694)
Electric Mobility...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
