New Member
   / New Member #1
Bob Blair
Edmonton, Alberta
Kubota 2370
Greetings to all. I just replaced an 8 year old Craftsman garden tractor with a Kubota 2370 which will allow me to do many more things around the acreage. On the first outing I used the front end loader to remove four large and irritating rocks and uproot a stump. I only wish I'd bought one sooner!
Bob
   / New Member #2
Welcome.
Consider a Piranha Tooth Bar as your first attachment. You do not want to make a habit with prying with one corner of your bucket. Attempt to keep the work load towards the center rather than ends.
LINK:
BXpanded Piranha Tooth Bar
   / New Member #5
Buy something heavy to carry mounted on the Three Point Hitch as a counter-balance to the FEL.
(Three Point counterbalance BEHIND the rear axle will also relieve stress on the front axle.)
You do not want to be carrying heavy rock load in the FEL, with the back end light, then have the FEL load shift, rolling the tractor over. Keep the loaded FEL LOW.
LINK:
https://www.google.com/search?clien...lance+site:tractorbynet.com&ie=UTF-8&oe=UTF-8
   / New Member
Thanks everyone. It comes with a ballast box, but I have a 40" rotary cutter on the back that the delivery guy said adds sufficient weight - he said to put the ballast box on if I am going to be operating the FEL without the rotary cutter in place.
   / New Member #7
Rotary Cutter is effective ballast because it is cantilevered, good advice.
   / New Member
Thanks Jeff for the great advice. This is going to be a learning experience for me, and keeping myself safe while taking good care of what is obviously a fine piece of equipment are my key goals.
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A55788)
2011 Mack GU713...
1996 Elgin Pelican Series S Street Sweeper (A53421)
1996 Elgin Pelican...
EZGO (A50324)
EZGO (A50324)
2008 Ford E-350 Versalift 29N 29ft Bucket Van (A55788)
2008 Ford E-350...
1494 (A55758)
1494 (A55758)
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
