Oil & Fuel New Member With A Question
   / New Member With A Question #1
docscott
Landrum, SC
Ford 1320
I just purchased a Ford 1320 with a FEL. It has a few bad hydraulic leaks. I just replaced 2 hydraulic connectors to the FEL. I got 5 gal. of Shield "Premium Universal Tractor Hydraulic Fluid" from Advance Auto. I don't have a manual for this tractor yet. I believe the Hydraulic fluid goes in the rear fill hole with the rubber cap. How do I know how much fluid to add. Also did I get the right fluid. Any information would be greatly appreciated.
   / New Member With A Question #2
read the specs ont he bottle.. does it say it meets ford/new holland M2C134 spec ( A-D possibilities )
if yes.. correct oil.
can't help you on level or fill-em-up hole...
It does meet Ford/New holland M2C134 spec. After reading your post I added about 1 gallon of Hydraulic fluid and started tractor. My new connectors didn't leak.:) I was also able to identify my other major leak.
Thanks a lot!
   / New Member With A Question #4
good luck.. post back
My other major hydraulic leak is under the tractor on the steel line going from the pump to the transmission. I'm waiting for my manual to arrive before I attempt to disassemble enough of the tractor to remove it.
   / New Member With A Question #6
pull a exploded diagram off the cnh site... might just be an oring or gasket...
Thanks for directing me to cnh.com. The exploded view is quite helpful. Unfortunately I'm pretty sure the problem is my very rusty steel tube.:(
   / New Member With A Question #8
metal? metal is easy to fix.. :)
   / New Member With A Question #10
I've got a 1310, whcih I belevie would be older than yours. It has a Dipstick in the HYD filler under the seat. It also has one in the front axle (4WD).
Be carefull with the FEL. Don't force the steering... Unless you are lucky enough to have power steering.
Keep us posted!
Dave
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A53472)
Adams Load Out...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2004 20ft Explorer Pontoon Boat and Trailer (A51573)
2004 20ft Explorer...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
