New Member with 1959 MF 202
   / New Member with 1959 MF 202 #1
jagbob23
Oakland, MI
MF 202
I'be been fascinated with all the information available on TractorByNet, so I joined. For the past 20 years, I have had a 1959 MF 202, industrial tractor with a Davis 101 loader, 35 to 40 HP gas engine, 2WD and about 4000 hours. I rebuilt the engine about 5 years ago and it runs well This is just about the only tractor that I have ever known. About 5 years ago the power steering went out. Everything seems to function properly, except excess pressure will force the PS fluid up and out at the base of the stering wheel. The dealer says the problem is inside the steering gear box at the base of the steering column. Right now it is arm-strong steering. My project for this Fall or Winter (again this year) is to pull the steering gear box and either rebuild it myself or have the dealer rebuild it in his slower season. The electrical charging system has only worked about 1/3 of the time that I have owned the tactor. I have tried to repair the system repeatedly but the improvements were always short term. At the same time as the stering is being rebuilt, I will also replace the generator and mechanical voltage regulator with an alternator and electronic voltage regulator.
I live on 10 acres of wooded rolling land. I use the tractor to maintain the property: brush mowing, finish mowing at times, grading, snow plowing, post hole drilling, moving brush, firewood, trailers and any other heavy objects. The tractor was extermely valuable when we built the house 20 years ago.
I am thinking of moving up to a Ford / New Holland 1920 or 2120 but that will be a different post.
   / New Member with 1959 MF 202 #2
Sounds like you only have a few problems with your tractor. I think the dealer is correct about the steering problem.. The electrical system is not very complex so you should be able to get the charging circuit operational, what have you repaired so far on it?
   / New Member with 1959 MF 202 #3
I don't know Jagbob, but it sounds like you have a great machine that works better than the new ones already... Nice! Picture?
   / New Member with 1959 MF 202 #4
G'day Jagbob AND spareparts1 to TBN from Downunder.
I think that this is my first 2fer 'welcome' in one thread.
Enjoy the site... both of you.
   / New Member with 1959 MF 202 #6
You will find help in the Massey Vintage Forum.
   / New Member with 1959 MF 202 #7
Welcome to TractorByNet!
I moved your thread to the General Vintage Tractors forum. :)
2017 International DuraStar 4300 Truck (A51692)
2017 International...
2012 John Deere 7230R (A53473)
2012 John Deere...
Echo Weedeater, Stihl Pole Saw & Predator Gas Auger (A50123)
Echo Weedeater...
2014 INTERNATIONAL MA025 BOX TRUCK (A53426)
2014 INTERNATIONAL...
2001 MONACO KNIGHT MOTOR COACH RV (A53426)
2001 MONACO KNIGHT...
2012 MACK GRANITE (A53843)
2012 MACK GRANITE...
