new member seeking help adding remotes to NH/Ford 1320
   / new member seeking help adding remotes to NH/Ford 1320 #1
clivejohnston
Montague, PE, Canada
New Holland 1320
Hello, first time on this forum. I have an early approx 1994 modle 1320 New Holland Utility Tractor.
I live in Eastern Canada and have small acreage.
I want to add hydraulic remotes. Tractor is stock and has power steering.Also it is hydrostatic.
Any help with this will be appreciated.
Thanks in advance ,
Clive Johnston
   / new member seeking help adding remotes to NH/Ford 1320 #2
hydraulics:
Type: open center
Capacity: 6.9 gal [26.1 L]
Pump flow: 6.4 gpm [24.2 lpm]
Total flow: 9.2 gpm [34.8 lpm]
Steering flow: 2.8 gpm [10.6 lpm]
Do you have FEL installed?
What so you want to use the remotes for?
If you want T-N-T, you might want a two spool valve with float and PB.
   / new member seeking help adding remotes to NH/Ford 1320 #4
Welcome from Wisconsin
hydraulics:
Type: open center
Thanks for responding.
I am not sure what FEL is. I know very little about hydraulics. I am wondering if I can come off the hydraulic manifold block and what kind of valve I need,
I plan to put a leveling cylinder on my scraper blade and use it in winter to lift the blade when I put it on front for plowing snow.
I may have to angle manually for now.
Clive
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
John Deere 455G Loader (A48837)
John Deere 455G...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
