New member in Southeast Georgia
   / New member in Southeast Georgia #1
CuzCumminsGuy
Jesup, Georgia
Mitsubishi D1500, 1998-1/2 Dodge D2500 w/ Compound Turbo's
I was told I needed to introduce myself, as I'm located in Southeast Georgia just out from a small town called Jesup. Was once a certified TIG welder, as I traveled the country for work on various welding jobs. Am retired from welding on the road, although I still do a little at home, both TIG and MIG, as well as some electrical and fabrication. Have been working on a Mitsubishi D1500 tractor for about 6 months. When I got it, the previous owner hadn't taken very good care of it. The radiator was set in place and was held in place with 4 pieces of electric fence wire, no fan shroud and water was leaking from the lower radiator hose. The air filter was a radiator hose with a sock over the end with a 1 inch hole in it! Since then, I found a new radiator for it, fabricated a steel fan shroud and built mounts that are welded into the frame rails fir it to fasten to, so the radiator can be mounted to the front and a 9 inch electric pusher fan with a thermostat can be mounted in front, as it now has an overflow tank as well. The fuel filter had been bypassed and was hanging off to the side on a long hose, so I fabricated a couple of mounts from the frame and installed some 3/8" stainless steel tubing bent with tubing benders going into a Swagelok fitting, then into a quarter turn valve, then into a coupling for the mount, then into a clear replaceable fuel filter, then into another piece of stainless tubing and into the banjo fitting at the injector pump. Replaced the bolts that hold the front cover in place where it pivots with a single long rod running through the frame with a pin on both sides, so it is easy to pull the pin, slide the rod out and remove the cover, but also installed waterproof wiring connectors going to an air horn and the front LED lights, so I can unplug them when the cover is removed. It had a grille from an old refrigerator, so I fabricated one from a piece of expanded metal and bolted it in place, welded up the holes for the original headlights and fabricated headlight mounts in front for 2 LED lights to mount, so I can angle them slightly for a better view at night. Have installed an 8 space blade type fuse panel and 4 heavy duty relays for the cooling fan, the LED lights and the horn, replaced the water pump with a new unit, had the alternator rebuilt, extended the front rails out so the battery can be mounted in a battery box with the bumper in front of that, replaced all of the wiring, discarded wiring that is no longer used such as for turn signals, replaced the glow plugs, the glow plug indicator and switch and wiring and all new battery cables with marine type cables and ends that are crimped on and heat shrunk. Couldn't locate new radiator hoses, so I ordered silicone hoses and clamps with aluminum ID tubing and built my own hoses. Had an aFe air filter made for it with a Filter Wears pre-filter custom made for it, then used a piece of silicone hose and mounted it over and in front of the radiator, which is held in place by using a muffler clamp. Am about to build a frame to mount to the top of both fenders using 1X2 inch rectangular steel tubing, then fabricate a roll-bar with an LED light bar which will look to the rear, then to use the same rectangular tubing to build angled bars on both sides that will go from this roll-bar to the front bumper, to keep low hanging tree limbs from trying to knock me off when I am using the bush hog, plus will be able to put a cover over the top in case it starts raining.
I drive a 1998.5 Dodge Cummins diesel pickup with compound turbo's, around 458 rear wheel horsepower when needed. Gets around 23 to 24 mpg when I keep my foot out of it. Replaced the stock tank with a custom 3/16 inch thick aluminum 85 gallon tank, it has a capper top on back and a Newton Billet aluminum lockable flush mount fuel filler neck, so it can be filled from the outside. Had a new 5.9 Cummins installed in January of 2017 and had both turbo's rebuilt. When I finish the Mitsubishi tractor, will continue building the front bumper, installing a Rigid 30 inch light bar, as it is now rusted so the POR-15 paint will be able to adhere to it, then will come the rear bumper, the fender flares, an overhead console and some work on the dash bezel using 2 part epoxy. Will build a bender to be able to bend and form ABS plastic, then to finish building an area under the dash to hold rocker switches, relays, fuse blocks, cables and wiring and the such, and will relocate the yellow top Optima gel batteries to the bed of the truck, along with an air receiver tank for a Nathan Air Chime train horn, then maybe build a rack for the top to install a solar panel or two. I always have at least 2 or 3 projects I am planning for in the future, as I love to build and to fabricate!
   / New member in Southeast Georgia #2
Welcome to TBN & the forum. A suggestion - break your posts into smaller paragraphs. Helps these old eyes from getting lost in the sea of words. You sure have been doing a lot of work on the Mitsubishi. I'd say your last six months have been busy.
Hey, thank you for my first response! Thank you, I appreciate you helping me with the suggestion!
Yeah, at 60 years of age, I am starting to get slower than I once was, but I still enjoy working. Have had some health issues with an open ulcer on my ankle off and on since '89, as it's open now. Last year was a diabetic, but put myself on a diet and have dropped about 80+ pounds since then and no longer diabetic.
Am still 6' 6" tall, the same as when I graduated high school. Weighed 235 back then, and am about the same weight now, just older! Things could be much worse, as many of my friends are no longer here.
One concern I have with the Mitsubishi is, I don't know if it has a hydraulic filter that needs to be serviced or now, and being I don't have a manual (being there was never one printed in English), I don't know who to contact to find out, or where it would be located, or if there is even a drain plug to drain it. I know what fluid to replace it with (AW46 Tractor Hydraulic Oil), but don't know where to fill it or how to check to make sure it is full. Any suggestions?
Before purchasing a rubber boot and putting it over the shifter, I looked inside the transmission and it looked like it had little or no fluid in the tranny, so I decided it was time to give it a overhaul and try to do things correctly for a change. Now if I could just find someone who knows more than I do about this model, I will be in better shape than I am now!
   / New member in Southeast Georgia #5
Hey - CCGuy, if you don't get any answers here to your Mitsubishi question - go over to the Mitsubishi/Satoh forum, under Brand Specific forums and ask your question(s) there. That will put you a lot closer to "ground zero" and folks who would have answers.
The path to follow is::: go to top of this page > homepage > shuffle down to Brand Specific forums > you will find Mitsubishi/Satoh listed here.
And BTW - you are not old - this poor 'ol bod was born in 1942. Good luck with your questions.
   / New member in Southeast Georgia #7
:welcome: to TBN...enjoy.
   / New member in Southeast Georgia #8
Welcome to the forum.I'm sure you get a lot of satisfaction in doing all this work yourself. Post us a few pics of your tractor.
   / New member in Southeast Georgia #9
Welcome to TBN!
I am about 115 miles due south of you, in S.W. Jax.
David from jax
Hey, I appreciate it! Yeah, it may not be exactly perfect, but at least I hope it has some improvement over the way I got it. When I get the transmission/ hydraulic concern addressed and seen about, maybe I can then figure out how to take some pics either with a smart phone or with a digital camera and download them on this HP desktop I got in December of last year, and post a few pics.
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
