New Member / Hydraulics
   / New Member / Hydraulics #1
Jim-Satoh
Mineral Springs, Arkansas
Satoh S-470 Buck
Hello Guys---I own a S-470 Buck with a roto-tiller, purchased it this week. Bill has manuals on the way. Question on the hydraulic lever returning to neutral after you raise the lift.
At times it will go all the way down and the lift. It will hold the lift if you hold the lever in neutral. Seems there was some sort of material placed behind the lever to tighten it up. Will adjusting the linkage help any.:)
   / New Member / Hydraulics #2
Welcome to TBN. Adjustment is probably all that's needed but without seeing it, I am just guessing. You may want to post this in the Satoh/Mitsubishi forum for input from the "Model specific" experts
   / New Member / Hydraulics #3
Welcome Jim. I have a Buck also. If you go to Bill's website, choose Parts, then scroll down to hydraulic controls you will get a page out of a manual. In the top left corner you will see the linkage parts that if adjusted properly will return the control lever to neutral when you are in the lifting mode. My linkage is gone and I just manually move it back to neutral to keep the relief valve from squealing. Is yours 4wd?
Hey Oliver---Finally a Buck owner on board. My Buck is 2WD. I got my manual yesterday from Bill---It has the linkage adjustment rod views in the book. I am going to try and adjust it.---Thanks Guy-----Jim
   / New Member / Hydraulics #5
The Buck is one heck of a tough little tractor. Congrats.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
1997 National RV Tropi-Cal Motorhome (A51694)
1997 National RV...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
