New member from Upstate NY
   / New member from Upstate NY #1
huntral
Upstate NY
2005 John Deere 5303 2 WD
Hello from Upstate NY!
I live in upstate NY. I have a 480 acre hobby farm. I have bought a 2005 John Deere 5303 2 wd. tractor with a loader. I'm looking for a few attachments! First I need rear wheel weights!! AND I'm in need of a 3 pt hitch Rotary mower, 6ft. Also looking for a tiller as well as a set of 2 bottom plows, nice 3pt. hitch disc harrow And or a drag harrow. A 3 pt. hitch seed spreader too!! and down the road I'd like a snowblower attachment. I don't farm it. I am putting in food plots! I'd like good used or reasonably priced new equipment. I'll be checking back in from time to time. Again, hello to all the members here. AL
   / New member from Upstate NY #4
Welcome! I have a similar size Kubota also used primarily for maintaining a 300 acre property and numerous food plots. Before you invest in wheel weights, have you considered filling the rear tires? Depending on what you use to fill them, it can be done for little cost. I did mine myself fairly easily. Of course, your temperatures get much lower there, which would be more of a concern.
Thanks for the replys!! I have considered juiceing the tires but they are radial rear tires and they tell me it is a better idea to use wheel weights ? I priced both around here. It is the same price to go either way. Weights are $800 for 800 lbs. - 400 ea side. juice is $750 (not calicum choloride) I figure if I poke a tire with juice in it I will have to pay again! so I figure weights is the better way to go. Problem with JD is you can't find any other weights that will work except JD weights!!
   / New member from Upstate NY #6
WELCOME TO TBN!
Hope you enjoy it here.
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
