I just purchased a new M7060HD12 ROPS with LA1154 FEL, cast rear weights, 2nd set remote hydraulics, fluid filled tires and upgraded wider R1 tries. I'm excited to say the least. I waited on purchasing a rotary cutter as I wasn't sure what I wanted. I have 93 acres that is a mixture of pasture, hills, red brush with some stumps. The brush makes up about 10-15 acres and it is fairly thick (3-4" at least I say). I've been looking at everything from Land Pride, Tennessee River, King Cutter, Bush Hog and Brown.
With that said, here are my goals:
1) Purchase something that is durable and up to the task.
2) Cutter should be affordable. I can't afford $10.5K for a Brown tree cutter.
3) Be able to maneuver in tighter spots.
With that said, I don't know whether to go with a 3-point setup or a pull-behind. I hear the 3-points are harder on the tractor. However, I'm concerned with backing up with a pull behind as well as raising/lowering to a desired height. What width should I consider? I've been looking at something in 7-8' range. However, a farmer friend is recommending I go with a 12' pull behind. The terrain is pretty hilly and rocky (Mid-East TN). Thoughts?
