New LS P7010C Owner
   / New LS P7010C Owner #1
hoosier44
Bloomington, Indiana
LS P7010C
Well my family is the proud owner of a new LS P7010C. Got the tractor delivered last week and already put 50 hours on it taking down old fence rows/pulling up posts and cutting about 60 acres of tall fescue and weeds. Love this tractor so far, it has done everything I've asked of it. Definitely is a little light in the rear but what new tractors aren't light these days? Planning on getting the rear tires filled and purchasing a box blade soon which will help. I have some first 50 hour maintenance questions I'd like to ask other P7010 owners.
I'll attach a pic of her
   / New LS P7010C Owner #2
Congrats on the tractor and welcome to the forum. The LS P series is a very capable tractor.
   / New LS P7010C Owner #4
It has been a while but IIRC the manual calls to change the hydraulic filter (just the filter not the oil) and change engine oil and filter at 50 hours. That was all the oil changing required for mine. Tightening of all bolts on the FEL mounts, wheel rims etc is required also. Especially look at the two bolts behind the fuel tank as both of those were several rounds loose while the rest were pretty tight. You can only use a combination wrench there due to minimal clearance so I can see why they might have been loose, plus you can barely see them at all.
Congratulation on your purchase. I know you will like it.
I had trouble with the front wheel final drive bolts loosening off especially on the left side. After the second tightening, I bought all new Gr 10 bolts and some Swedish built 2 piece lock washers(available at Fastenal-can never remember the name of them) and blue Loctite. Replaced them all, with the new washers and Loctite and they have not loosened again.
Great tractor with lots of engine Horsepower, much more power than the tractors weight can handle. You really need to fill those rear tires and maybe even get some rear cast iron wheel weights for optimum traction. It wont pull very much in 2 wheel drive with the FEL on because it is just too light in the rear end without something heavy on the rear. I filled the FEL with oak wood once and in 2 WD it wouldn't back up a slight incline before I filled the tires with water and I had a box blade on the rear at the time. One really needs about 1000# of wheel weights plus tire ballast when using ground engaging implements.
Thanks guys. I appreciate the info Gary, I will definitely be adding some weight to the rear as soon as I can.
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2019 CATERPILLAR 299D2 XHP SKIDSTEER (A51242)
2019 CATERPILLAR...
